  2. Pointwise
  3. Connect inflation layers around a corner between two split...
  • State Verified Answer
  • Replies 13
  • Subscribers 10
  • Views 18607
Connect inflation layers around a corner between two split bodies
IE202408012526
IE202408012526 over 2 years ago
Hello everyone,
I am using Pointwise to create a inflation layer around a corner between 2 bodies.
I want to define a porous zone in one of the bodies, therefore I cannot connect them directly and create all inflation layers together because I need seperate blocks for each volume.
The current status of my mesh is shown in the 2 pictures below:
Is it possible to connect the inflation layers in an angle of 45 degress or similiar to that, maybe as some kind of boundary condition in the extrude settings when creating the boundary layers?
An example of what I would like to get is shown in this picture:
But then I can't treat them as 2 seperate bodies / blocks anymore.
Do you have any advice?
Thank you very much!
  • Claudio M Pita
    Claudio M Pita over 2 years ago in reply to IE202408012526 +2 verified
    Hi, Thank you very much for the update on this. Unfortunately, it is hard to understand your T-Rex set up and to answer your questions by looking at two images. At this point, I would recommend you…
  • Claudio M Pita
    Claudio M Pita over 2 years ago +1
    Hi, Thank you very much for your question. Unfortunately, it is a bit hard for me to understand the block topology in this case. In other words, I am not understanding where each block ends. Is there…
  • Claudio M Pita
    Claudio M Pita over 2 years ago in reply to IE202408012526 +1
    Hi, Thank you very much for the information. Yes, I would recommend using the T-Rex algorithm as it will allow you to create the grid that you are looking for in a fraction of the time. Furthermore…
  • Claudio M Pita
    0 Claudio M Pita over 2 years ago in reply to IE202408012526
    Thank you very much for the follow up question(s).
    • Perhaps I am not understanding correctly from the images, but it seems that you obtained with the extrusion something similar to what I showed with T-Rex. Based on the images, it seems that T-Rex should provide more flexibility in this case.
    • The advantage of using T-Rex in this case is that you can use the Create, Periodic, Extrusion functionality to create the periodic domains, then assemble your block, and then let the solver complete the entire grid (aniso and iso) while maintaining the periodicity (i.e., both domains are the same). If the geometry you are showing is just a "slice" of the entire geometry, you will need that periodicity. In other words, perhaps I am misunderstanding, but it seems that you are doing more work than needed using the normal extrusion in this case.
    • As for your second question:
      • You can create quad-dominant domains (i.e., surface grids containing triangles and quads)
      • You can create a block (i.e., volume grid) containing prisms and hexes in the anisotropic region (i.e., boundary layer) and tets and pyramids in the isotropic region.
      • You can also create a block containing prisms and hexes in the anisotropic region and hexes, pyramids and tets in the isotropic region. This are called Voxel meshes.
    If at all possible, please review some of the videos presented in the User Manual (under Grid, Solve) and let us know what would be your end goal.
    Best regards.
  • IE202408012526
    0 IE202408012526 over 2 years ago in reply to Claudio M Pita
    Thanks for your advice.
    I have now tried using your advices regarding T-Rex. It might be better for the periodic boundary.
    I still do not get the connection between the blocks properly.
    I defined all the walls for the inflation layers and created a Match-boundary for the domains separating my blocks.
    Then the following appears:
    Push attributes is turned on and the boundary conditions are set like this:
    Do you have any suggestions which setting is missing in my case?
    Thanks a lot!
  • Claudio M Pita
    +1 Claudio M Pita over 2 years ago in reply to IE202408012526
    Unfortunately, it is hard to understand your T-Rex set up and to answer your questions by looking at two images. At this point, I would recommend you log a support ticket in the Cadence Online Support (COS) portal if possible.
    If you are a student, you may not have access to log cases. In this case, I would recommend you work with the person in charge of the license (usually a professor) who should be able to log a case so we can take a good look at the grid for a more accurate resolution.
    Thanks much for your time.
    Best regards.
    • Vote Up +2 Vote Down
