  2. Results analysis
  3. The color contour is not visible
  • State Verified Answer
  • Subscribers 7
  • Views 6962
Colinda
Colinda over 4 years ago
When I try to visualize a color contour on a surface in the Results analysis, it is not visible. How to fix this?
  • Gaurav
    Gaurav over 4 years ago in reply to Colinda +2 verified
    If you are analyzing your result on some plane, then that plane have to be selected but the essential condition is first you have to click on Run results analysis.
  • Colinda
    Colinda over 4 years ago +1 verified
    Make sure to select the correct computation at the bottom left of the graphical area. It is also important to start the analysis: The icon just in front of the simulation name in the tree: Run results…
  • Colinda
    +1 Colinda over 4 years ago
    • The icon just in front of the simulation name in the tree: Run results analysis.
    • In the Pie the button "Enable analysis on selected computation".
    When a spinning wheel is shown for the simulation in the tree, it means it is ready to visualize the results.
  • Gaurav
    +1 Gaurav over 4 years ago in reply to Colinda
    • Vote Up +2 Vote Down
