  2. Results analysis
  3. Multiple Frames in Cf view
  • State Verified Answer
  • Subscribers 8
  • Views 10708
sima101f
sima101f over 3 years ago
Hello. Does some know or guide how to create multiple frames in single screen in cfview? for example i want to see my b2b surfaces in b2b view at 10%, 50% and 90% span in  single a frame window. So to say three different pictures in a single picture.
Thanks in advance
  • Colinda
    Colinda over 3 years ago +1 verified
    Hi, You may also want to look at the section in the CFView user guide describing how to create multiple views: Cfview > User Guide > Graphical User Interface, Projects & Views > Views Manipulation…
  • Gaurav
    0 Gaurav over 3 years ago
    Cutting planes at certain span heights can be obtained in B2B views by using the Create Cutting Plane dialogue box or the Blade to Blade Surface dialogue box, (Geometry / Blade to Blade Surface... or the item in Quick Access Pad). The required documentation is also given in CFView User guide Chapter 5 (Visualization of Blade-to-Blade Surfaces.) available on support.cadence.com
  • sima101f
    0 sima101f over 3 years ago in reply to Gaurav
    Hello.
    Thank you for your quick response. I do understand how to create b2b at diffrent spans. What i am asking is can i see 3 spans for eg at 10%, 50% and 90% in a single frame ?
  • Gaurav
    0 Gaurav over 3 years ago in reply to sima101f
    Yes it is possible, you can create B2B for 3 span.
  • sima101f
    could you please tell how ?
  • Gaurav
    In the CFView top tool bar click on the geometry tab & select the blade to blade option a small tool bar opens as shown below
    Now you can select the desired value of S (Span) then apply & save. Likewise you can do for other S values.
