  2. Results analysis
  3. Post processing LES vs RANS
  • Subscribers 8
  • Views 3742
LJ202505013133
LJ202505013133 over 1 year ago
Which post processing tool is recommended for comparing LES (made using CharLES), RANS and wind tunnel oil flow visualization results to each other?
  • Gaurav
    Gaurav over 1 year ago +1
    First, what data type do you need to compare the contour or line plots? Second, for RANS simulation, which software are you using? If you are using multiple simulation software, you can export the result…
  • Gaurav
    0 Gaurav over 1 year ago
    If you are using multiple simulation software, you can export the result file and utilize the Tecplot software.
    Please go through the following link before making any comparisons.
     Overview of DNS, LES, and RANS Turbulence Models
    The discretization methods of LES and RANS differ. In LES, the governing equations are discretized using filters, which resolve large-scale turbulent eddies and model the smaller ones. However, in RANS, discretization is based on resolving the mean flow and modeling turbulent fluctuations.
  • LJ202505013133
    0 LJ202505013133 over 1 year ago in reply to Gaurav
    Many thanks.
    Can Tecplot work well for > 1 billion cell mesh LES simulations?
  • Gaurav
    Yes, Tecplot can function properly, but it depends on the amount of RAM you have available.
