  2. Turbo
  3. Calculating of k-epsilon
  • State Verified Answer
  • Replies 7
  • Subscribers 6
  • Views 7093
sriluta
sriluta over 3 years ago
I am examining a turbine stage with only one stator. I expect supersonic velocities and use the k-omega SST model with RANS 2- equation for the steady-state simulation. My medium is water vapor and I have an inlet temperature of about 1700 degrees.
Now I want to calculate the k-epsilon values and there is an online tool for that. Using the turbulence length scale, turbulence intensity and freestream velocity I can calculate the values I am looking for. According to the tool, the turbulence length at the inlet to the turbine stage can typically be defined as 5% of the channel height. The channel height should be the span of the blade I think, which is 0.024m for me. The freestream velocity is estimated to be about 1000m/s and the turbulence Intensity 5%. This gives me values for k: 3750 m^2 / s^2 and epsilon: 17222974 m^2 / s^3. Are the values not a little too high ? Am I doing something wrong ? Btw. I am using omnis
  • sriluta
    sriluta over 3 years ago in reply to Colinda +1 verified
    Hey, sure. On the website cfd-online.com, in online tools/ Turbulence Properties, Conversions & Boundary Estimations its possible to calculate the values. I then clicked on the following: Turbulence variables…
  • sriluta
    0 sriluta over 3 years ago
    problem solved :)
  • domen
    0 domen over 3 years ago in reply to sriluta
    Hi, Good to know! I wanted to ask you which online tool you used, there are some websites that return crazy values :)
  • sriluta
    0 sriluta over 3 years ago in reply to domen
    hey domen, from cfd-online.com
  • Colinda
    0 Colinda over 3 years ago in reply to sriluta
    Would you mind sharing the solution you found? It may be interesting for others here as well.
  • sriluta
    +1 sriluta over 3 years ago in reply to Colinda
    Hey, sure. On the website cfd-online.com, in online tools/ Turbulence Properties, Conversions & Boundary Estimations its possible to calculate the values. I then clicked on the following:  Turbulence variables (k, ε, ω) from turbulence intensity (Tu), length-scale (TuL) and freestream velocity (U∞). So the turbulence intensity and length- scale are fixed values. I changed a little bit the freestream velocity, from 1000 m/s to 1500 m/s and used the ne values for k and epsilon to see if my results changed or not, and there was no difference in my result for different values of k and epsilon, therefore  that's why I left the values as they are, so in my case it just fit.
