  2. Turbo
  3. Creating a FNMB between a solid blade domain and a fluid...
  • State Verified Answer
  • Subscribers 7
  • Views 5546
Creating a FNMB between a solid blade domain and a fluid domain within a turbo configuration simulation
KBBKBB
KBBKBB over 3 years ago
currently, I want to perform a CFD CHT calculation of a turbo-configuration, where the blade is considered as a solid domain. The mesh of the fluid domain of the turbo configuration (using the row wizard) and the mesh of the solid domain (using HexPress) are already generated. Currently, I am using OMNIS 5.2.
This webinar comes pretty close to what I am trying to achieve, although I do not have such a complex tip geometry and I do not use FIDELITY pointwise:
How to Efficiently Mesh Complex Turbomachinery Blade Tips with High Accuracy | Engineering.com
I was wondering how exactly Mr Teixeira managed to connect the blade solid domain with the fluid domain.
Within the "connection manager" in the "domain context", the boundaries of the blade, which are part of the fluid domain, cannot be selected to be part of a FNMB. But somehow, a connection between the solid blade and the surrounding fluid was created in the above linked webinar.
I could not find any contact info of Mr Teixeira, but given that he is principal application engineer at cadance, I was hoping somebody could provide me an answer for this issue or his maybe his contact info.
Many thanks
Paul
  • domen
    domen over 2 years ago in reply to KBBKBB +1 verified
    Hi Paul, it's a known limitation, unfortunately. We are going to work on it in the following versions of Fidelity, but as you found out, in 2023.1 we can't use the blade boundaries that are generated…
  • domen
    domen over 2 years ago in reply to domen +1
    Hi again, we are going to fix this in FI 2023.2, if you want to give it a try again.
  • Gaurav
    0 Gaurav over 2 years ago
    Sorry for the late response. For a better understanding of CHT and the use of connection manager, you have to go through Fidelity tutorial no. 6, namely CHT in a water-cool jacket. As of today, I don't know whether you are using OMNIS5.2 or Fidelity. This tutorial works for both software. If you have access to support.cadence.com, you can also download the geometry of the Turbine Mark II (tutorial no. 2 of Fine/Open Beginner). This problem is also related to conjugate heat transfer (CHT). You can also try Turbine Mark II with Fidelity or OMNIS, which will give you a very clear understanding of CHT and the connection manager.
    GS
  • KBBKBB
    0 KBBKBB over 2 years ago
    Hi, thanks for the answer.
    I am using Fidelity.
    I know how to use the connection mager for CFD CHT in general.
    My problem is (still) the one I have written in my original post:
    "Within the "connection manager" in the "domain context", the boundaries of the blade, which are part of the fluid domain, cannot be selected to be part of a FNMB."
    THe boundaries of the blade are automatically created while using the turbo wizard.
    Many thanks
    Paul
  • domen
    +1 domen over 2 years ago in reply to KBBKBB
    We are going to work on it in the following versions of Fidelity, but as you found out, in 2023.1 we can't use the blade boundaries that are generated by the Wizard/geomTurbo. One workaround is to import the IGG project (exported from Fidelity, for example): the boundaries of the blade are going to be available there.
  • domen
    0 domen over 2 years ago in reply to domen
  • KBBKBB
    0 KBBKBB over 2 years ago in reply to domen
    Great news! Thank you.
