  2. Turbo
  3. Autogrid/ Turbo Meridonal Lines
  • State Verified Answer
  • Subscribers 6
  • Views 2886
Zuriko
Zuriko over 3 years ago
Hello together,
I am currently meshing an Bypass-Configuration in OMNIS Turbo and am struggeling at the meridonal lines, please have a look in the attached image:
The lines beginning at the interface/inlet of the stator row (black line) are having a strange course.
Maybe some of you have an ideato fix that ?
Best regards
  • domen
    domen over 3 years ago +1 verified
    Hi, we added in the latest versions a "clear distribution" option, that resets the flow paths. The option should be available when the R/S interface is selected. Which version are you using?
  • domen
    +1 domen over 3 years ago
  • Zuriko
    0 Zuriko over 3 years ago in reply to domen
    Thank you for your answer!
    I've fixed the problem by using a different geometry file, but I haven't found that "clear distribution" option. I am using OMIS 5.2.
