  2. Turbo
  3. how to calculate the Mass-averaged total pressure loss ...
  • State Verified Answer
  • Subscribers 6
  • Views 4084
how to calculate the Mass-averaged total pressure loss coefficient
sriluta
sriluta over 3 years ago
Hey,
iam using Omnis/turbotemplate and investigating a stator. For my mesh independence study I would like to calculate the total pressure loss coefficient ( w= 1 - Pt/Pt_inlet) upstream and downstream of the stator.  Do I have to select in results analysis  for the integration type: absolute weighted mass averaged and in w : absolute total pressure ?
thx Hussein
  • domen
    domen over 3 years ago +1 verified
    Hi, The absolute weighted mass average is going to take the absolute value of the mass flow rate for the integral. If you have reversed flow, both directions are taken into account with the same sign…
  • domen
    +1 domen over 3 years ago
    The absolute weighted mass average is going to take the absolute value of the mass flow rate for the integral. If you have reversed flow, both directions are taken into account with the same sign.
    If you use non-absolute weighted mass average, the integral keeps the signs as they are for the direction of velocity (the product of v and A)
    The w is indeed the absolute total pressure.
  • sriluta
    0 sriluta over 3 years ago in reply to domen
    ah Thx, so I did a color contour plot plot with the absolut total pressure in the 3d view. Then created  cutting planes normal to the flow direction, on the position I want to, and on the planes I calculated the absolute weighted mass average total pressure
