  2. Turbo
  3. Export blade surface mesh
  • State Verified Answer
  • Subscribers 6
  • Views 4136
aescudero
aescudero over 3 years ago
Dear all,
I have a 3D mesh of a compressor blade in turbo, created with Autogrid. When I export the mesh in .cgns format I get the full mesh, however, I would like to export just the mesh over the blade surface, is it possible ? Can someone explain how to do it?
Thank you,
Alvaro
  • domen
    domen over 3 years ago in reply to aescudero +1 verified
    No, with Omnis we can't export the surface mesh. You get the CGNS out and try to extract the surface mesh with other tools (like our IGG, for example)
  • domen
    0 domen over 3 years ago
    In which format would you like to export the surface mesh? STL, or CGNS?
    We don't have an automatic way of doing this, you need to export the surfaces from IGG after selecting them.
  • aescudero
    0 aescudero over 3 years ago in reply to domen
    I would like to export the surface mesh as a .cgns file
    Probably I didn't specify correctly how I am doing it, I am using Autogrid as mesher for the mesh setup, but the tool is Omnis (turbo module). Could you please explain me how to do it with this tool?
    Thank you
  • domen
    +1 domen over 3 years ago in reply to aescudero
