  2. Turbo
  3. Determine vortex rotation direction
  • State Verified Answer
  • Subscribers 7
  • Views 3358
Delfim Sa
Delfim Sa over 2 years ago
i am looking for a way to determine the direction a vortex is rotating in CFView.
Delfim Sá
  • Gaurav
    Gaurav over 2 years ago +1 verified
    A straightforward method involves first pinpointing the vortex's location and then creating the cutting plane at that particular location. After that, in the top toolbar select Quantity>Field Data> Basic…
  • Gaurav
    +1 Gaurav over 2 years ago
    A straightforward method involves first pinpointing the vortex's location and then creating the cutting plane at that particular location. After that, in the top toolbar select Quantity>Field Data> Basic Quantities and select the velocity field. Then click on Representation tab and select the vector type. The vector field will give you a clear picture. You can also create a different cutting plane to verify how the vortex is evolving.
  • Delfim Sa
    0 Delfim Sa over 2 years ago in reply to Gaurav
    Thank you very much
