  2. Turbo
  3. CFView: extraction of quality images.
  • State Verified Answer
  • Subscribers 6
  • Views 2768
Delfim Sa
Delfim Sa over 2 years ago
I have two questions.
The first one is: What is the best method to extract images from CFView with the highest quality passive? So when I zoom in, it doesn't get blurry. Is this possible?
The second one is: Is it possible to change the color of the ISO surface or normal surface (like hub, blade, etc.) to increase contrast and help read the images?
Delfim Sá
  • Colinda
    Colinda over 2 years ago +1 verified
    Hi Delfim, Did you see these best practices in the documentation: Search Results for "CFView high quality pictures" (cadence.com) To change the color of a surface, first select the surface in the…
  • Colinda
    +1 Colinda over 2 years ago
    Hi Delfim,
    To change the color of a surface, first select the surface in the Surfaces subpanel and then follow the instructions in the "Modify Rendering Color" of the CFView manual.
    The Surface Material Editor allows to change the color, light reflections, opacity and reflection properties.
    Best regards,
    Colinda
