  2. Turbo
  3. CPU time in Omnis/turbo
  • State Verified Answer
  • Subscribers 7
  • Views 3007
cfd enthusiast
cfd enthusiast over 2 years ago
Hello everyone,
in Omnis when i run a simulation I can see the simulation time in the command manager. However I am not sure if I am seeing the CPU time or total Time, since it is only called elapsed time.
Also I can't find the elapsed time in the log files of the simulation. Is it called differently?
Thank you!
  • Gaurav
    Gaurav over 2 years ago +1 verified
    In the case of Open Solver, navigate to the output and select the fourth option. The screenshot is attached for reference. But in the case of Turbo solver, you need to check with the command manager.
  • Gaurav
    +1 Gaurav over 2 years ago
