  2. Turbo
  3. Python API in the Simulation context
  • State Verified Answer
  • Subscribers 6
  • Views 3172
cfd enthusiast
cfd enthusiast over 2 years ago
Hello Everyone,
I am currently writing a script to automate the simulation context.
In the simulation context I want to access the static pressure of the inlet and outlet in the Turbo initial solution tab.
I belive I have to fill them out correctly if i choose "for turbomachinery" in the initial solution tab under one of the domains.
I can't find the code to set those static pressures in the API user manual.
  • Colinda
    Colinda over 2 years ago +1 verified
    Hi, The static pressures can be accessed through the commands: set_inlet_initial_static_pressure ( v ) set_outlet_initial_static_pressure ( v ) So for the tutorial of the multistage axial compressor…
  • Colinda
    +1 Colinda over 2 years ago
     set_inlet_initial_static_pressure(v)
    set_outlet_initial_static_pressure(v)
    So for the tutorial of the multistage axial compressor it writes for example in this way:
    ## InititalConditions
    # Domain1 Settings
    main_flow_par = dom_parameters.InitialSolutionParameters.MainFlowVariablesParameters(domain1)
    main_flow_par.set_initial_solution_choice('Turbo')
    domain1.set_inlet_initial_static_pressure(90000)
    tur_flow_par = dom_parameters.InitialSolutionParameters.TurbulentQuantitiesParameters.InitialValuesParameters(domain1)
    tur_flow_par.set_k_free(150)
    tur_flow_par.set_epsilon_free(12587e4)
    #Domain2 Settings
    print("Row 2: Rotating?",domain2.is_rotating())
    main_flow_par2 = dom_parameters.InitialSolutionParameters.MainFlowVariablesParameters(domain2)
    main_flow_par2.set_initial_solution_choice('Turbo')
    domain2.set_inlet_initial_static_pressure(85000)
    domain2.set_outlet_initial_static_pressure(100000)
