  2. Turbo
  3. CFView: Unsteady state visualiation
  • Replies 8
  • Subscribers 7
  • Views 8096
Delfim Sa
Delfim Sa over 2 years ago
I am doing an unsteady state simulation of a stator and rotor, and now I can't visualize the rotor in different positions relative to the stator.
Do I need to have multiple output files?
I am using the steady state initiation.
Delfim Sá
  • Gaurav
    0 Gaurav over 2 years ago
    Please specify which software you are using, Fine/Turbo or Fidelity, along with the version. If you are using Fine/Turbo, then in the CFView, click on the "Geometry" tab. You can locate this tab at the top of the toolbar. Now, you have two options: "Repetition on/off" and "Repetition Number," which you can select accordingly.
  • Delfim Sa
    0 Delfim Sa over 2 years ago in reply to Gaurav
    I am using FINE/Turbo CFView. This is an unsteady simulation, and I want to see the rotor in different positions relative to the stator (different time steps?).
    Do I have to enable the Multiple files option? When I ask CFView to read the result file, it doesn't ask me what time step I want to as it says in the manual. It just opens a file with the rotor in the position that it ended.
    Also, is there anywhere on the manual convergence criteria for unsteady simulation on FINE/Turbo?
  • Gaurav
    0 Gaurav over 2 years ago in reply to Delfim Sa
    Hi, Yes, you need to choose the "Multiple Files" option to visualize the rotor's rotation. I do not understand what you are trying to say "Manual convergence criteria".
  • Delfim Sa
    Thank you.
    I wanted to ask if the Fine/Turbo user guide contains any information about convergence criteria for unsteady.
  • Colinda
    0 Colinda over 1 year ago in reply to Delfim Sa
    As described in the user guide of Fine Turbo, it is important to reach convergence for each inner iteration. The criterium can be defined in the interface. However, it is often a good idea to base the judgement of convergence not just on the residuals but also on a relevant quantity in one or multiple control points.
    If the inner iterations are well converging, it is then important to run sufficient periodic cycles to get a converged unsteady solution: the solution over one period is reasonably the same compared to the previous period.
