  2. Turbo
  3. transient table in openlabs?
  • Replies 9
  • Subscribers 6
  • Views 11362
sriluta
sriluta over 2 years ago
Hello together,
iam doing an unsteady Simulation with Omnis. At the inlet iam simulating among others the total temperature as you can see in the picture. The total temperature changes with the azimuth angle theta and the time. So far I reconstructed the points with the fourier series and inplemented in openLabs. Is it also possible to insert a transient table in openlabs as I see an example in the documentary?
Tt(theta, time) = 1650 + (-112)*cos(1.9*tCoord - PI*Time/timePeriod) + 4*sin(1.9*tCoord - PI*Time/timePeriod) and with the other terms.  TimePeriod is the time, the shockwave needs to travel around the annulus of my axial turbine.
greetings Hussein
  • Colinda
    Colinda over 2 years ago +1
    Hi Hussein, If you wish to define the temperature as a function of theta and time using a table, I don't think OpenLabs is needed. Did you already look into the possibility to use the Profile manager…
  • Colinda
    Colinda over 2 years ago in reply to sriluta +1
    Hi Hussein, As you can see in the documentation of the Profile manager, you can define a .csv file that will have a header like this: time, theta, temperature Then you add points of the temperature…
  • sriluta
    0 sriluta over 2 years ago in reply to Colinda
    thx, unfortunately I get the error message: [NIOmnisSolverApl::getParameterDescription] Invalid combination of interpolation axis ( 5,12) of function absolute total pressure.
  • Colinda
    0 Colinda over 2 years ago in reply to sriluta
    Your header for the profile of absolute total pressure is also something like:
    time, theta, pressure
  • sriluta
    Yes
  • Colinda
    Can you please confirm which version you are using?
    If you are using a very old version, I would recommend to make a quick try in Fidelity 2023.2.
    If hotline support is included with your license, and you are using a supported version, you may also create a support case on support.cadence.com.
