  2. Turbo
  3. transient table in openlabs?
  • Replies 9
  • Subscribers 6
  • Views 11126
sriluta
sriluta over 2 years ago
Hello together,
iam doing an unsteady Simulation with Omnis. At the inlet iam simulating among others the total temperature as you can see in the picture. The total temperature changes with the azimuth angle theta and the time. So far I reconstructed the points with the fourier series and inplemented in openLabs. Is it also possible to insert a transient table in openlabs as I see an example in the documentary?
Tt(theta, time) = 1650 + (-112)*cos(1.9*tCoord - PI*Time/timePeriod) + 4*sin(1.9*tCoord - PI*Time/timePeriod) and with the other terms.  TimePeriod is the time, the shockwave needs to travel around the annulus of my axial turbine.
greetings Hussein
  • Colinda
    Colinda over 2 years ago +1
    Hi Hussein, If you wish to define the temperature as a function of theta and time using a table, I don't think OpenLabs is needed. Did you already look into the possibility to use the Profile manager…
  • Colinda
    Colinda over 2 years ago in reply to sriluta +1
    Hi Hussein, As you can see in the documentation of the Profile manager, you can define a .csv file that will have a header like this: time, theta, temperature Then you add points of the temperature…
  • Colinda
    0 Colinda over 2 years ago
    Hi Hussein,
    Did you already look into the possibility to use the Profile manager? You can create a .csv file with your data.
    If that does not meet your requirements, could you please explain why not?
    Best regards,
    Colinda
  • sriluta
    0 sriluta over 2 years ago in reply to Colinda
    Hi Colinda,
    thx for your answer. Didn't see this option before,  but how can I also define then the timePeriod, the time the shockwave needs to travel around the annulus?  I think I have to pre-calculate the temperature values incorporating the phase shift and that's it?
    greetings Hussein
  • Colinda
    0 Colinda over 2 years ago in reply to sriluta
    Hi Hussein,
    Then you add points of the temperature profile in function of theta for the first time t1, then the profile for a next time t2, etc.
    t1 theta11 T11
    t1 theta12 T12
    t1 theta13 T13
    t2 theta21 T21
    t2 theta22 T22
    t2 theta23 T23
    So you have a "grid" of points covering the theta range at the inlet, and define the temperature values for the points of this grid, at each computed time.
    I hope this helps to set up your profile?
    Best regards,
    Colinda
  • sriluta
    Hi Colinda, exactly thx. Just need to know, how to define the header for arct(Vt/Vz) ( angle from axial direction). Maybe just arct(Vt/Vz) ?
  • Colinda
    For the quantity to impose, like arct(Vt/Vz) you can use a simple name like flowangle.
    I never use special characters like ( or / in the profile header. It seems to work though.
