  2. Turbo
  3. Python API: Simulation context
  • Subscribers 7
  • Views 3044
cfd enthusiast
cfd enthusiast over 2 years ago
Hello Everyone,
I'm trying to automate my simulation settings and I've stumbled upon a hurdle. I want to set the initial solution in my domain to "From solution" and then set my last finished simulation as the simulation to initialize with. I have figured out the first
line of code, which would be: (HexstreamDomainNumericalParameters)....set_initialization_type("From solution"). However, I can't seem to figure out which line of code I should use to load the initial solution from a certain simulation.
Thank you!
  • Gaurav
    0 Gaurav over 2 years ago
    Hi, I have taken the script file for tutorial 1 of fidelity, “Volute.” You can find the script file under “Fidelity tutorials.” Navigate to “support.cadence.com.” You can easily find the link.
     First, try to run the “python.py” script file. I created a separate script file for easy understanding; the screenshot is attached below for reference.
     In the modules, I have added the new module “from fidelity.plugins import euranus_parameters”
     You can read the Python API documentation and go through the “SIMULATION MODULES” under that to find the “fidelity.simulation”. In that, you can search for the function “set_initial_solution”. Also, you can go through the “SOLVER PLUGINS MODULES” and check the “fidelity.plugins.euranus_parameters”
     Please change the “project_path” in the screenshot and set it accordingly.
