  2. Turbo
  3. FineTurbo: Solver gets stuck
  • Subscribers 8
  • Views 4022
Delfim Sa
Delfim Sa over 1 year ago
I am using FineTurbo 18, and when I put in a simulation, most of the time, it gets stuck on this:
BLOCK 47 : Transfer initial solution for turbomachinery
BLOCK 4 : Transfer initial solution for turbomachinery
BLOCK 31 : Transfer initial solution for turbomachinery
BLOCK 43 : Transfer initial solution for turbomachinery
BLOCK 37 : Transfer initial solution for turbomachinery
BLOCK 42 : Transfer initial solution for turbomachinery
BLOCK 11 : Transfer initial solution for turbomachinery
BLOCK 28 : Transfer initial solution for turbomachinery
BLOCK 14 : Transfer initial solution for turbomachinery
Then, I need to stop it and rerun it until it passes this phase.
What do I do to avoid this?
I am planning on doing an optimization, and I don't want this type of problem.
What do I do?
Regards and Merry Christmas and a Happy New Year,
Delfim Sá
  • Gaurav
    0 Gaurav over 1 year ago
    Based on the block index, the project has a log of blocks. It could be a multi-stage machine with a large mesh. You can isolate the issue by running each row separately to see which takes more time.
  • Delfim Sa
    0 Delfim Sa over 1 year ago in reply to Gaurav
    Sorry for the late reply. But that is not what is happening here. The solver just gets stuck. If I stop the solver and restart it a few times, it doesn't get stuck anymore. The problem is that the solver gets stuck. I don't know if I made my point clear.
  • KBBKBB
    0 KBBKBB over 1 year ago
    Hi Delfin,
    Some of my colleagues, who primarily use the legacy Fine/Turbo tools (but the newer versions), occasionally experience similar issues. They often have to restart the simulation to get it running properly.
    Are you working on a Windows system? Running the simulations on Linux might help avoid such problems. Personally, I mainly work with Fidelity and haven’t encountered these issues.
    I agree—getting this kind of error during an optimization run is really inconvenient.
    Here’s what I would suggest:
    • Periodically check the log file where the output is written (is that the .std file, perhaps?). If the last entry doesn’t change for a certain amount of time, abort the simulation and restart it.
    • Alternatively, you could monitor the size of the .std file. If it doesn’t increase over time (as it should while more entries are being added), take that as a sign to abort and restart the simulation.
