  2. Turbo
  3. Turbomachinery Mesh Topologies: When to Use H, C, or O-Grids...
  • Subscribers 6
  • Views 2070
Turbomachinery Mesh Topologies: When to Use H, C, or O-Grids?
Gaurav
Gaurav 8 months ago
The choice of mesh topology directly impacts accuracy, convergence, and computational cost in turbomachinery simulations.
 H-Grid
Structure: Grid lines form an “H” pattern across the domain.
Best Use Cases:
    • Far-field regions where flow is relatively uniform.
    • Simple geometries with minimal curvature.
    • Capturing inlet/outlet boundary conditions in turbomachinery passages.
Advantages:
    • Easy to generate and extend to infinity (good for external flows).
    • Efficient for coarse far-field resolution.
Limitations:
    • Poor resolution near trailing edges and wakes.
    • Not ideal for curved blade surfaces.
C-Grid
Structure: Grid wraps around the trailing edge, forming a “C” shape.
Best Use Cases:
    • Turbomachinery blades with sharp trailing edges.
    • Capturing wake development and downstream flow separation.
    • High-speed flows.
Advantages:
    • Excellent wake resolution behind blades.
    • Smooth clustering near trailing edges.
Limitations:
    • More complex to generate than H-grids.
    • May require hybridization with O-grids near leading edges.
O-Grid
Structure: Grid lines wrap around the blade surface in concentric “O” rings.
Best Use Cases:
    • Resolving boundary layers around curved surfaces (airfoils, turbine blades).
    • Capturing secondary flows in blade passages.
    • Handling strong curvature and tip leakage flows.
Advantages:
    • High-quality boundary layer resolution.
    • Smooth orthogonality near walls → better y+ control.
Limitations:
    • Difficult to extend to far-field without combining with H-grids.
    • More computationally expensive due to clustering near walls.
Key Considerations:
Hybrid Topologies: O-grids near blades, C-grids at trailing edges, and H-grids in the far field are often combined for optimal accuracy and efficiency.
Physics-driven choice: Select topology based on whether the priority is boundary layer resolution (O-grid), wake capture (C-grid), or far-field uniformity (H-grid).
Computational trade-off: O-grids give the best accuracy near walls but increase cell count; H-grids are cheapest but least accurate near complex blade regions.
If anyone would like to share additional information based on their experience, it would benefit CFD users.
