  3. Silk Rotate skill file
  • Replies 23
  • Views 28382
Jocko
Jocko over 14 years ago
I have this old skill program, RotateSilkAssyRD.il. Its a great tool to get ref des align, re-sized and reset to start
working on cleanup.  I've used it on 15.7, but now on 16.1 and 16.3 I get an error.
When I envoke the skill I get this error.
E- *Error* fprintf: argument #1 should be an I/O port (type template = "ptg") - nil
Not sure where I got it and when, I may have stripped out the authors name in the past.
A great time saver when your working with a lot of parts.
;#   Rotate Reference Designator Text on Silkscreen and Assembly Layers    #
;#  This routine rotates Silkscreen and Assembly Reference Designators     #
;#  such that they are all "rightward reading".  This means that all RDs   #
;#  will read left to right if they are horizontal, or bottom to top if    #
;#  they are vertical.                                                     #
;#  Additionally, any Assy RD will automatically be moved to the component #
;#  origin.        #
;#  Usage:  rotate_silkassy (from within Allegro)                          #
;#  Register Program Name #
axlCmdRegister("rotate_silkassy" 'RotateSilkAssyRD)
;# MAIN Program Starts Here. #
(defun RotateSilkAssyRD ()
  ; ==== Initialize Global Variables ====
  Layer_List = nil
  Text_List  = nil
  Layer_List = nil
  justify    = ""
  LRBT = t   ; Left to Right, Bottom to Top
  LRTB = nil ; Left to Right, Top to Bottom
  RLBT = nil ; Right to Left, Bottom to Top
  RLTB = nil ; Right to Left, Top to Bottom
  CenterAssy = t
  ChangeTextSize  = nil
  TextBlockLarge  = 6
  TextBlockMedium = 3
  TextBlockSmall  = 1
  tblk_large  = "6"
  tblk_medium = "3"
  tblk_small  = "1"
  SilkTop = nil
  SilkBot = nil
  AssyTop = nil
  AssyBot = nil
  silktop_layer = "REF DES/SILKSCREEN_TOP"
  silkbot_layer = "REF DES/SILKSCREEN_BOTTOM"
  assytop_layer = "REF DES/ASSEMBLY_TOP"
  assybot_layer = "REF DES/ASSEMBLY_BOTTOM"
  sym_savex  = -1
  sym_savey  = -1
  sym_saveparent = nil
  SetupDir()
  if( axlOKToProceed() then
      ; ==== Create and Display the User Interface ====
      createRotateRDForm()
      fFile = strcat( FormDir "rotateRDForm.form" )
      Form = axlFormCreate( (gensym)  fFile  nil 'rotateRDForm_Action t)
      axlFormSetField(Form "LRBT" LRBT)
      axlFormSetField(Form "LRTB" LRTB)
      axlFormSetField(Form "RLBT" RLBT)
      axlFormSetField(Form "RLTB" RLTB)
      axlFormSetField(Form "CenterAssy"      CenterAssy)
      axlFormSetField(Form "TextBlockLarge"  TextBlockLarge )
      axlFormSetField(Form "TextBlockMedium" TextBlockMedium)
      axlFormSetField(Form "TextBlockSmall"  TextBlockSmall )
      axlFormDisplay( Form )
  else
      printf("E- Please terminate your interactive command .\n")
  );endif OKToProceed
); end defun - MAIN Program
;# doRotateSilkAssy - When OK is hit, perform Reference Designator Rotation #
;#                   Do each layer separately to improve performance.       #
(defun doRotateSilkAssy ()
   axlClearSelSet()
   axlSetFindFilter( ?enabled   (list "noall"  "text")
                     ?onButtons (list "text")
   axlMsgPut("Silk/Assy RD rotation started.")
   foreach( layer Layer_List
            axlVisibleDesign(nil)
            axlVisibleLayer( layer t)
            Text_List = axlGetSelSet( axlAddSelectAll() )
            if( length( Text_List ) != 0 then rotateSilkAssy() )
            axlClearSelSet()
            axlFlushDisplay()
            axlMsgPut(strcat( layer " Rotation completed.") )
          ); foreach
; ==== Turn On Top/Bottom Silk & Assembly Layers, if they were changed. ====
   Display_List = list("paramLayerGroup:BOARD GEOMETRY/paramLayer:OUTLINE")
   if( AssyTop == t then
       Display_List = cons("paramLayerGroup:PACKAGE GEOMETRY/paramLayer:ASSEMBLY_TOP" Display_List)
       Display_List = cons("paramLayerGroup:REF DES/paramLayer:ASSEMBLY_TOP"          Display_List)
   if( AssyBot == t then
       Display_List = cons("paramLayerGroup:PACKAGE GEOMETRY/paramLayer:ASSEMBLY_BOTTOM" Display_List)
       Display_List = cons("paramLayerGroup:REF DES/paramLayer:ASSEMBLY_BOTTOM"          Display_List)
   if( SilkTop == t then
       Display_List = cons("paramLayerGroup:PACKAGE GEOMETRY/paramLayer:SILKSCREEN_TOP"  Display_List)
       Display_List = cons("paramLayerGroup:REF DES/paramLayer:SILKSCREEN_TOP"           Display_List)
   if( SilkBot == t then
       Display_List = cons("paramLayerGroup:PACKAGE GEOMETRY/paramLayer:SILKSCREEN_BOTTOM" Display_List)
       Display_List = cons("paramLayerGroup:REF DES/paramLayer:SILKSCREEN_BOTTOM"          Display_List)
   foreach( Layer Display_List
            val = axlGetParam( Layer )
            val->visible = t
            axlSetParam( val )
); end defun - doRotateSilkAssy
;# rotateSilkAssy - Check layer type, Get RD Coordinates and rotation.#
;#                  Rotate RD in place if wrong orientation, change   #
;#                  text justification to "center".                   #
(defun rotateSilkAssy ()
   foreach( text_id Text_List
            ;axlMsgPut(strcat("Processing: " text_id->text))
            ; ==== retrieve current information on text id              ====
        changeit = 0
        text   = text_id->text
        xy     = text_id->xy
            txt_x  = xCoord( xy )
            txt_y  = yCoord( xy )
            txt_tblk = text_id->textBlock
        ; ==== Change Text to "Center" Justification for ease of use ====
            txt_jus= text_id->justify
            if( txt_jus != "CENTER" then changeit = 1 )
        ; ==== Check current rotation against preferred orientation ====
              ; ==== Change if necessary                                  ====
        txt_rot= text_id->rotation
            if( LRBT == t then
                if( txt_rot == 180 then
                    txt_rot  = 0
              changeit = 1
                if( txt_rot == 270 then
                    txt_rot  = 90
              changeit = 1
              );endif LRTB
        if( LRTB == t then
                    txt_rot  = 0
              changeit = 1
                if( txt_rot == 90 then
                    txt_rot  = 270
                    changeit = 1
              );endif LRBT
        if( RLBT == t then
                    txt_rot  = 0
                    changeit = 1
                    txt_rot  =  90
                    changeit = 1
              );endif RLBT
        if( RLTB == t then
                    txt_rot  = 0
                    changeit = 1
                    txt_rot  = 270
                    changeit = 1
              );endif RLTB
              ; ==== ON Assembly Layers, if requested by user in form ====
            ; ====    Move Assy Text to Calculated Symbol origin    ====
            ; ====    Change Text Block Sizes for easier reading.   ====
            txt_lyr = text_id->layer
            if( txt_lyr == assytop_layer || txt_lyr == assybot_layer || txt_lyr == silktop_layer || txt_lyr == silkbot_layer then
                if( CenterAssy == t then
                    foreach(childid text_id->parent->children
                            if( childid->layer == "PACKAGE GEOMETRY/PLACE_BOUND_TOP" ||
                                childid->layer == "PACKAGE GEOMETRY/PLACE_BOUND_BOTTOM" then
                                sym_llx = xCoord( xCoord( childid->bBox ))
                                sym_lly = yCoord( xCoord( childid->bBox ))
                                sym_urx = xCoord( yCoord( childid->bBox ))
                                sym_ury = yCoord( yCoord( childid->bBox ))
                                sym_x   = (sym_urx + sym_llx) / 2
                                sym_y   = (sym_ury + sym_lly) / 2
                              );endif childid
                           );end foreach
                    if( txt_rot ==   0 then sym_y = sym_y - 20 )
                    if( txt_rot ==  90 then sym_x = sym_x + 20 )
                    if( txt_rot == 180 then sym_y = sym_y + 20 )
                    if( txt_rot == 270 then sym_x = sym_x - 20 )
                    xy       = list( sym_x sym_y )
                    changeit = 1
                  );endif CenterAssy
                if( ChangeTextSize == t then
                    changeit = 1
                    txt_tblk = tblk_large
                    rdalpha  = substring( text 1 1 )
                    if( rdalpha == "C" || rdalpha == "R" then
                        txt_tblk = tblk_small
                    if( rdalpha == "D" then
                    rdalpha  = substring( text 1 2 )
                    if( rdalpha == "RN" || rdalpha == "RP" then
                        txt_tblk = tblk_medium
                if( rdalpha == "FB" || rdalpha == "KP" then
              if( rdalpha == "TP" then
                  );endif ChangeTextBlock
              );endif txt_lyer
          ; ==== Do text movement, if anything has changed ====
;VAN HUYNH modified here (add _RD)
            if( changeit == 1 then createTextBlock_RD())
      ); endforeach
); end defun - rotateSilkAssy
;# createTextBlock - Create text record and write information to    #
;#                   the database.                                  #
(defun createTextBlock_RD ()
  textBlock = txt_tblk
  rotation  = txt_rot
  parent_id = text_id->parent        ; symbol association
  mirrored  = text_id->isMirrored    ; t/nil
  justify   = "CENTER"               ; "LEFT" "CENTER" "RIGHT"
  ; ==== setup defstruct for text insertion ====
  textOrientation = make_axlTextOrientation( ?textBlock textBlock,
                                             ?rotation  rotation,
                                             ?mirrored  mirrored,
                                             ?justify   justify
  ; ==== Add new text and delete the existing text if successful ===
  update = axlDBCreateText( text, xy, textOrientation,
                            text_id->layer, parent_id
  if( update != nil then
    ; axlMsgPut("Update Succeeded.")
      axlDeleteObject( list( text_id ))
  else
      axlMsgPut( strcat( "Update Failed on " text ) )
    ); endif
); end defun - createTextBlock_RD
 ;# Form CallBacks - Determine Allegro command to execute   #
 ;#                  based on the user's selection          #
(defun rotateRDForm_Action (Form)
   (case Form->curField
     ("SilkTop"
        SilkTop=Form->curValue
     ); end "SilkTop"
     ("SilkBot"
        SilkBot=Form->curValue
     ); end "SilkBot"
     ("AssyTop"
        AssyTop=Form->curValue
     ); end "AssyTop"
     ("AssyBot"
        AssyBot=Form->curValue
     ); end "AssyBot"
     ("LRBT"
        LRBT=Form->curValue
        orient_0   = t
        orient_90  = t
        orient_180 = nil
        orient_270 = nil
     ); end "LRTB"
     ("LRTB"
        LRTB=Form->curValue
        orient_0   = t
        orient_90  = nil
        orient_180 = nil
        orient_270 = t
     ); end "LRTB"
     ("RLBT"
        RLBT=Form->curValue
        orient_0   = nil
        orient_90  = t
        orient_180 = t
        orient_270 = nil
     ); end "LRTB"
     ("RLTB"
        RLTB=Form->curValue
        orient_0   = nil
        orient_90  = nil
        orient_180 = t
        orient_270 = t
     ); end "LRTB"
     ("CenterAssy"
        CenterAssy=Form->curValue
     ); end "CenterAssy"
     ("ChangeTextSize"
        ChangeTextSize=Form->curValue
     ); end "ChangeTextSize"
     ("TextBlockLarge"
        TextBlockLarge=Form->curValue
        sprintf( tblk_large "%L" TextBlockLarge )
     ); end "TextBlockLarge"
     ("TextBlockMedium"
        TextBlockMedium=Form->curValue
        sprintf( tblk_medium "%L" TextBlockMedium )
     ); end "TextBlockMedium"
     ("TextBlockSmall"
        TextBlockSmall=Form->curValue
        sprintf( tblk_small "%L" TextBlockSmall )
     ); end "TextBlockSmall"
     ("done"
        ; ==== cons puts the list together in reverse order
        if( AssyBot == t then Layer_List = cons( assybot_layer Layer_List ) )
        if( AssyTop == t then Layer_List = cons( assytop_layer Layer_List ) )
        if( SilkBot == t then Layer_List = cons( silkbot_layer Layer_List ) )
        if( SilkTop == t then Layer_List = cons( silktop_layer Layer_List ) )
        doRotateSilkAssy()
        (axlFormClose Form)
        (axlCancelEnterFun)
        deleteFile( fFile )
     ); end "done"
     ("cancel"
        (axlFormClose Form)
        (axlCancelEnterFun)
        deleteFile( fFile )
     ); end "cancel"
   ); end case
 ); end defun - rotateRDForm_Action
  ;# End Form CallBacks    #
  ;# createTitleBlockForm - Main User Interface Form         #
  ;#                        Brought up by executing command. #
(defun createRotateRDForm ()
   Form  = outfile( fFile "w")
   fprintf(Form "FILE_TYPE=FORM_DEFN VERSION=2\n")
   fprintf(Form "FORM\n")
   fprintf(Form "FIXED\n")
   fprintf(Form "PORT 77 20\n")
   fprintf(Form "HEADER \"Rotate Silkscreen/Assembly Reference Designators V2.0\"\n")
   fprintf(Form "TILE\n")
   fprintf(Form "GROUP \"Select Layers to Rotate\"\n")
   fprintf(Form "GLOC 2 1\n")
   fprintf(Form "GSIZE 72 4\n")
   fprintf(Form "ENDGROUP\n")
   fprintf(Form "FIELD \"SilkTop\"\n")
   fprintf(Form "FLOC 3 3 \n")
   fprintf(Form "CHECKLIST \"Silkscreen-Top\" \n")
   fprintf(Form "ENDFIELD\n")
   fprintf(Form "FIELD \"SilkBot\"\n")
   fprintf(Form "FLOC 20 3 \n")
   fprintf(Form "CHECKLIST \"Silkscreen-Bottom\" \n")
   fprintf(Form "FIELD \"AssyTop\"\n")
   fprintf(Form "FLOC 37 3 \n")
   fprintf(Form "CHECKLIST \"Assembly-Top\" \n")
   fprintf(Form "FIELD \"AssyBot\"\n")
   fprintf(Form "FLOC 54 3 \n")
   fprintf(Form "CHECKLIST \"Assembly-Bottom\" \n")
   fprintf(Form "GROUP \"Select RD Orienation\"\n")
   fprintf(Form "GLOC 2 5\n")
   fprintf(Form "GSIZE 32 13\n")
   fprintf(Form "GROUP \"Ref Des Alterations\"\n")
   fprintf(Form "GLOC 36 5\n")
   fprintf(Form "GSIZE 38 13\n")
   fprintf(Form "TEXT \"Horizontal           Vertical \"\n")
   fprintf(Form "TLOC 6 7 \n")
   fprintf(Form "ENDTEXT\n")
   fprintf(Form "FIELD \"LRBT\"\n")
   fprintf(Form "FLOC 3 9 \n")
   fprintf(Form "CHECKLIST \"Left to Right     Bottom to Top\" \"rotate_group\" \n")
   fprintf(Form "FIELD \"LRTB\"\n")
   fprintf(Form "FLOC 3 11 \n")
   fprintf(Form "CHECKLIST \"Left to Right     Top to Bottom\" \"rotate_group\" \n")
   fprintf(Form "FIELD \"RLBT\"\n")
   fprintf(Form "FLOC 3 13 \n")
   fprintf(Form "CHECKLIST \"Right to Left     Bottom to Top\" \"rotate_group\" \n")
   fprintf(Form "FIELD \"RLTB\"\n")
   fprintf(Form "FLOC 3 15 \n")
   fprintf(Form "CHECKLIST \"Right to Left     Top to Bottom\" \"rotate_group\" \n")
   fprintf(Form "FIELD \"CenterAssy\"\n")
   fprintf(Form "FLOC 37 7 \n")
   fprintf(Form "CHECKLIST \"Center Assembly RDs at Part Origin\" \n")
   fprintf(Form "FIELD \"ChangeTextSize\"\n")
   fprintf(Form "FLOC 37 9 \n")
   fprintf(Form "CHECKLIST \"Change Text Block Sizes\" \n")
   fprintf(Form "TEXT \"Large  Text Block: \"\n")
   fprintf(Form "TLOC 39 11 \n")
   fprintf(Form "TEXT \"Medium Text Block: \"\n")
   fprintf(Form "TLOC 39 13 \n")
   fprintf(Form "TEXT \"Small Text Block: \"\n")
   fprintf(Form "TLOC 39 15 \n")
   fprintf(Form "FIELD \"TextBlockLarge\"\n")
   fprintf(Form "FLOC 55 11 \n")
   fprintf(Form "INTSLIDEBAR 3 3\n MIN 1\n MAX 60\n FGROUP\"TxtBlock\" \n")
   fprintf(Form "FIELD \"TextBlockMedium\"\n")
   fprintf(Form "FLOC 55 13 \n")
   fprintf(Form "FIELD \"TextBlockSmall\"\n")
   fprintf(Form "FLOC 55 15 \n")
   fprintf(Form "FIELD done\n")
   fprintf(Form "FLOC 6 18\n")
   fprintf(Form "MENUBUTTON \"Done\" 6 3\n")
   fprintf(Form "FIELD cancel\n")
   fprintf(Form "FLOC 16 18\n")
   fprintf(Form "MENUBUTTON \"CANCEL\" 6 3\n")
   fprintf(Form "ENDTILE\n")
   fprintf(Form "ENDFORM\n")
   close(Form)
); end defun  - createRotateRDForm
  • Charlie Davies
    Charlie Davies over 14 years ago
    It looks like there might be an issue with SetupDir.  This looks to be an external function defined in another file.  The lines that define the filename to open
    are referencing a variable (FormDir) that is not is not set in this file.  I suspect the outfile is failing and as a result, the form is not being written.
    Charlie
    321.727.6235
  • eDave
    eDave over 14 years ago
    You didn't include the SetupDir function but if I set FormDir to "./" the utility works for me.
    That's a quick way to alter the silkscreen but do a search on this forum for my autosilk code - it does some extra stuff that you might like.
    Dave
  • Jocko
     Dave,
    Not knowing how to write skill, I'm at a lost on what and where I should add the line to this code to fix it.
    Could you send the file back that you fixed and runs.
     Thanks for any help
    Jacque Cottingim @ cottjr5@sbcglobal.net
  • eDave
    Hi Jacque,
    See attached.
    Regards, Dave
    RotateSilkAssyRD.zip
  • AndyZhang
    AndyZhang over 13 years ago
    Hello Deve,
    Since we often have some silksreen and assmbly which are not expected to be moved, could you please help us update the code?
    if the symbol has been fixed or locked, we will not adjust the silk and assmbly.
    If you need more detail information, please let me know.
