  3. Utility to output a single symbol from a design
  • Replies 7
  • Subscribers 167
  • Views 19426
joma
joma over 9 years ago
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/jm_5F00_write_5F00_1_5F00_symbol_5F00_public.zip
Hi, I recently discovered the skill command "axlWritePackageFile( car(axlSelectByName("SYMTYPE" symbol-name))->definition )" which writes a single footprint
from a pcb. The good thing about it is it writes the symbol .dra and.psm files with all associated padstack files. I find this very handy from time to time. The bad thing
is it is a pain to be typing skill commands like this so I have created a user interface form to make things easier. As I have benefited from lots of utilities found in this
forum I thought I would contribute something of my own (however simple).
To load the code type "skill load("jm_write_1_symbol_public.il"). The file shoud be in your skill path.
To run the code type "write one symbol" on the command line.
All feedback welcome.
Load the Skill code using"skill load("RotateSilkAssyRD.il)" - See more at: community.cadence.com/.../17911
  • DE202408202727
    DE202408202727 over 9 years ago
    Hi Jim,
    Nice utility. Great example of the usefulness of Skill.
    I'm curious about the reason for putting functions inside functions. It's unusual to me but probable stems from your experience with other programming languages? If you do this you should avoid the duplicate use of variable names (SymForm).
    The statements putd('jmWriteOneSym nil) etc. are unnecessary I think. I am curious as to why you have done this. Is it regarded as good practice?
    A little known feature in 16.6 is the ability to create a form using a string. This would avoid the need to create a form file that you need to delete later.
    Cheers,
    Dave
  • joma
    Hi Dave,
    Thanks for the feedback and I'm glad you like it.
    In fact the style comes from my inexperience and the the fact that I sometimes have had problems passing multiple returning values from functions to a calling function. I figure I can use one let() command to cover a group of functions and play happily with all of the variables without leaking globals. Probably not good practice but it seems to work. This gives just one warning in sklint but no errors so I was happy to stick with it. I think that as I get to grips with skill I will probably change to a more conventional style.
    The putd statements are just something I copied from another program from the forum assuming that they were useful. They probably are useless so if I create a version 1.1 I will delete them.
    Creating a form from a string is a better method. Do you know where I can read about this?
    Cheers,
    Jim
  • B Bruekers
    B Bruekers over 9 years ago
    A simple example for a string form:
    p = nil
    sprintf(p "FILE_TYPE=FORM_DEFN VERSION=2\tFORM\tFIXED\tPORT 50 10\tHEADER \"TITLE_OF_FORM\"\tTILE")
    sprintf(p "%s\tTEXT \"HELLO\" \tTLOC 2 1\t\tENDTEXT" p)
    sprintf(p "%s\tENDTILE\tENDFORM" p)
    defvar(fw_test nil)
    axlFormCreate( 'fw_test list("test_form" list(p)) '("CENTER" ) 'fw_callback t)
    axlFormDisplay(fw_test)
    basically you need to make 1 long string that contains the form. New lines need to be \t (tab), not \n or \r.
    Then you need to call axlFormCreate with this : list("test_form" list(p)) the "test_form" can be any string you like.
    The rest of the form function, creation, handling etc is equal to the file-based form.
    To return multiple variables you can or return a list like list( result_a result_b) and then use car() and cadr() to extract the results returned from the function
    Another way is to use a global.
    First you need to generate a global with defvar() and then at the end use var_name = 'unbind. The last statement unbinds/removes the global variable.
    Don't put this global variable into the let(), otherwise it won't work.
    A hint, you can use the form variable to store return values like;
    axlFormCreate( 'fw_test ....
    fw_test->test = "hello"
    and then you can recall the value by simply using 'fw_test->test'.
    Since in the above example the fw_test is a global, you can access it anywhere in your functions.
    Bram
  • joma
    Thanks Bram, good info.
  • YH202508126436
    YH202508126436 over 1 year ago
    Hi Joma ,
    I was wondering — if I change the line width of a component in the board, why does it still appear with the old width after exporting the DRA using [axlWritePackageFile]?
