  2. Functional Verification
  3. W,imc.license.analysis_failed: Failed to check out 'Affirma_sim_analysis_env...
  • Subscribers 66
  • Views 8128
W,imc.license.analysis_failed: Failed to check out 'Affirma_sim_analysis_env' license. Failed to acquire IMC license. LMF-03513
Eivingam
Eivingam over 9 years ago
imc does not work on my computer but it work on other computers.
On my computer, lmstat -a:
Users of Affirma_sim_analysis_env:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of Incisive_Desktop_Manager:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of Incisive_Enterprise_Simulator:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of Incisive_HDL_Simulator:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of Incisive_P2C_Methodology:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of Incisive_Specman_interactive:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of Incisive_Verif_Environ:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of VERILOG-XL:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of CaptureCIS:  (Total of 2 licenses issued;  Total of 1 license in use)
It seems to be something wring with imc, I can run simulation and everything else, but imc wont run. and the licenses are unused.
Any suggestions?
  • tpylant
    tpylant over 9 years ago
    Can you be more specific about what doesn't work? Do you get an error message? Does a window come up and then go away? Are any log files generated?
  • Eivingam
    The IMC start up windows comes up and disappears before the error appears in the terminal. So basically I can't run the program.
    Here's the error messages(also content from mdv.log):
    Failed to acquire license for IMC
    16:04:51:0673 [com.cadence.system] [main] FATAL - Failed - (LMF-03513): License call failed for feature Affirma_sim_analysis_env, version 15.2 and quantity 1. The license server search path is defined as XXXX@XXXXXX. The FLEXnet error message is as follows,
    FLEXnet ERROR(-513, 7006, 0): Error List Returned (-513,7006) ; Can't Connect to License Server (-15,3002) ; Can't Connect to License Server (-15,3002) ; Internal Flexlm Error (-506,1022)
    Run 'lic_error LMF-03513' for more information.
    imc.log is empty
  • Eivingam
    imc splash screen starts but the main gui does not. Incisive starts with no problems. We have an incisive XL license.
  • muffi
    muffi over 9 years ago
    This is due to a bug in the license server utilities, and the fix is found in cdslmd/lmgrd version 11.13.
    Please refer the following article on https://support.cadence.com.
    support.cadence.com/.../ArticleAttachmentPortal;pageName=ArticleContent&sq=005d0000005nKM1AAM_2017217172452688
  • Eivingam
    Thank you :D
