  2. RF Design
  3. set a random input data
  • Subscribers 63
  • Views 21072
kamel
kamel over 16 years ago
hi
did anybody know how to enter a random input data to perform a simulation using spectre (eg 1101...)
thank you
  • tkhan
    tkhan over 16 years ago
    you can use rand_bit_stream from ahdlLib or vsource from analogLib. with vsource its not actually random, you can define the pattern arbitrarily.
    Pattern parameters:
    45      data              The bit string. A string that contains a series of the four states, 1 0 m z.
    46      rptstart=1        The starting bit when repeating. The data repeats from the specified bit to the end of the bit string. The parameter should be an integer from 1 to the length of the bit string.
    47      rpttimes=0        The repeat times. The output will maitain the state of the last bit after the last repeat. If its value is negative, the string repeats forever.
    Actually the vsource in spectre now supports a new type, prbs, which produces a pseudo-random bit stream.
    The vsource component in analogLib has not yet been enhanced to support this though. There's an enhancement request for that though.
  • kamel
     thank you all i appreciate
    unfortunetly it doesnt't work with the version of spectre i have, it expect a 6.2 or later.
     i think it's possible to write a module in Verilog -ams that's supports rhe generation of a sequence of bit, but how to include it ?
    regards,
    kamel
    Kamel,
    The rand_bit_stream in ahdlLib should work whatever version you're using. It's been there for at least 10 years, and is a Verilog-A model that you can always customize if it doesn't meet your needs.
  • kamel
    thanks Andrew
    i was talking about vsource i tried it and i got an error message according to the version of spectre that i m using.
    regards kamel
