  3. spectre, redefinition of subckt definition
  • Views 23414
demsar
demsar over 14 years ago
Hi!
Is it possible to redefine a subckt definition in spectre? I have red in UltraSim there existst an option duplicate_subckt=warn-I cant find something similar for spectre. Just for clearification, renaming an existing subckt definition is not an option, I would realy need to use the same subckt name.
Thanks in advance!
Blaz
    From "spectre -h options" :
     109     duplicate_subckt=error
                              Allow duplicated subckt defintion. If set to `yes',
                              it allow to duplicate subckt definition;
                              if set to `no', it disallow duplicate subckt
                              definition.. Possible values are error, ignore and
                              warning.
    So yes, it's possible with spectre too. In a spectre netlist you can just add:
    myOpts options duplicate_subckt=warning
    In ADE (don't think this is on the form - I've not checked), you'd do Simulation->Options->Analog and go to the Additional Parameters field and enter "duplicate_subckt=warning"
  • demsar
    Great, thanks for fast reply!
    Blaz
