  3. ADE Ldesign with complex variable
  • Views 18385
TotoPyx
TotoPyx over 11 years ago
In the graphical ADEL interface, i use parametrized design variable in ADEL such as:
GAIN=15
GFB=mod(GAIN+1,2)
G15=if(GAIN==15 1 0)
during the netlist parsing, GFB is well evaluated while G15 is not parsed correctly.
Both syntax are correct in the calculator window. What is not good in my syntax, is it dependent of the simulator used (spectre or eldo)? How can I make conditional test on a variable?
Totopyx
  • Frank Wiedmann
    Frank Wiedmann over 11 years ago
    For Spectre with ADE-L, you can use G15=GAIN==15?1:0 (the so-called ternary operator). For ADE-XL, take a look at http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11764448.
  • TotoPyx
    Ok, so I think that my problem comes from the fact I am using eldo. I was not really sure that the syntax was compatible.
  • Frank Wiedmann
    In Eldo, you should be able to use G15=EVAL(GAIN==15?1:0)
  • TotoPyx
    It Works!! thanks for the help Frank
  • Nandag
    Nandag over 6 years ago in reply to TotoPyx
    Hi Frank
    This solution doesn't seem to work in ADE-L when I use it to assign a string to a variable. For example:
    leak=0
    moscor=(leak==1? "top_ff" : "top_ss")
    I get a syntax error:
    Cannot run the simulation because syntax error `Unexpected quoted string ""top_ff"' was encountered at line 9, column 38.
    Is there any other way to assign a conditional string to a variable in ADE-L? I use ICADVM 18.1.500.
    Thank You
    -Nanda
