  3. STDOUT error while running LVS PVS
  • Views 15321
MoMiner1870
MoMiner1870 over 10 years ago
Hello all, I am getting an error while running LVS PVS,  port cannot be drained STDOUT.
What is STDOUT?  is this a problem with the design or a problem with some type of output file?
Thanks for your help!
    This message means that the normal output of the program can't be flushed - probably because whatever it is writing to cannot keep up - maybe because a disk filled up?
    I've not seen any reports of this message with PVS LVS though.
    So perhaps contacting customer support makes most sense.
  • MoMiner1870
    Thanks Andrew, I'll work with the IT dept at my university.  I think you are right, its probably a disk space problem.
