  3. [Solved] Unbound pins when running Assura LVS in Virtuoso...
  • Replies 8
  • Views 24535
[Solved] Unbound pins when running Assura LVS in Virtuoso Layout Suite L
dpalomeq
dpalomeq over 9 years ago
I am getting 'unbound pin' errors when running Assura LVS in a layout manually done in Virtuoso Layout Suite L. It seems that Assura LVS is not extracting the pins, which are done in the MET1 Pin layer with the Create->Pin assistant.
How can I solve this?
Thanks in advanced.
David.
  • dpalomeq
    dpalomeq over 9 years ago +1
    I solved it! Instead of creating PINs, I just had to create Labels in the PIN layer (MET1 purpose) . This way, I have successfully extracted the schematic from the layout. Thanks for your help! David.
  • Quek
    Quek over 9 years ago
    Hi David
    You can check the "pinLayer" cmd in Assura extract.rul file to determine the correct layer-purpose pair which should be used for creating pins. Perhaps you need to use met-drawing instead of met-pin?
    Best regadrs
    Quek
  • dpalomeq
    I've checked the file and it seems that layer is correct. Isn't it?
    MET1_sympin = pinLayer( "MET1" type( "pin"))
    MET1_pinPurpose = layer( "MET1" type( "pin"))
    David.
  • Quek
    Hi David
    You can also check the .erc file in Assura run directory for any warnings. The pins might have been dropped due to shorts, etc.
    Best regards
    Quek
  • dpalomeq
    Hi Quek,
    LVS is reporting me this:
    So I think Assura is not extracting the pins at all.
    David.
  • Quek
    Hi David
    Thanks for the info. Would you please provide the contents of the .erc file in your Assura run directory? I would like to know if there are any warnings/errors in it.
    Best regards
    Quek
  • dpalomeq
    Hi Quek,
    I haven't run any ERC yet. I have just passed the DRC without errors (I have suppressed one warning regarding MET density) and now I am trying to run the LVS.
    David.
  • Quek
    Hi David
    Actually I do not mean Electrical Rule Check (ERC). There is a file in your Assura run directory which has extension .erc. E.g.
    yourRunName.erc
    Would you please provide this file?
    Quek
  • dpalomeq
    I solved it!
    Instead of creating PINs, I just had to create Labels in the PIN layer (MET1 purpose). This way, I have successfully extracted the schematic from the layout.
    David.
