  3. Adding elements to open form in SKILL
  • Replies 7
  • Subscribers 150
  • Views 29516
ToMWUT
ToMWUT over 17 years ago
I’ve got a question about a form. I have a form created with hiCreateAppForm function and then it was also displayed using hiDisplayFunction.
Is there any possibility using for example a callback function of a button on this form to add something to the form for example another field, so the form would reload and the user wouldn’t feel the difference? I would like to add another element to ScrollRegion.
Any piece of code would be much appreciated.
ToM
    Andrew Beckett over 17 years ago
    ToM,
    This code gives an example of adding fields on a form. To add them onto a scroll region, the first argument to the hiAddField or hiAddFields function would be form->scrollRegion (where scrollRegion is the ?name of the scroll region field).
    /* oferExample.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Feb 09, 1999
    Modified   Mar 02, 1999
    By         A.D.Beckett
    Example code to demonstrate how to use various form functions,
    use of loading and saving templates, dynamic field addition, etc.
    Note that the templates don't include the values of the
    dynamic fields - that's an exercise for the reader!
    SCCS Info: @(#) oferExample.il 06/26/14.15:20:15 1.5
    *                       oferCreateForm()                       *
    *                     Create the main form                     *
    procedure(oferCreateForm()
        let((libName cellName viewName browse userData templateFile templateLoad templateSave
            sep1 sep2 sep3 radio optionTwo optionThree)
            ; template loading and saving
            templateFile=hiCreateStringField(
                    ?name 'templateFile
                    ?prompt "Template File"
            templateLoad=hiCreateButton(
                    ?name 'templateLoad
                    ?buttonText "Load"
                    ?callback "oferLoadTemplate()"
            templateSave=hiCreateButton(
                    ?name 'templateSave
                    ?buttonText "Save"
                    ?callback "oferSaveTemplate()"
            ; cellView specification
            sep1=hiCreateSeparatorField(?name 'sep1)
            libName=hiCreateStringField(
                    ?name 'libName
                    ?prompt "Library Name"
                    ?callback "ddsUpdateSyncWithForm()"
            cellName=hiCreateStringField(
                    ?name 'cellName
                    ?prompt "Cell Name"
            viewName=hiCreateStringField(
                    ?name 'viewName
                    ?prompt "View Name"
            browse=hiCreateButton(
                    ?name 'browse
                    ?buttonText "Browse"
                    ?callback "oferSyncBrowser()"
            sep2=hiCreateSeparatorField(?name 'sep2)
            ; example radio button
            radio=hiCreateRadioField(
                    ?name 'radio
                    ?prompt "Radio"
                    ?choices list("One" "Two" "Three")
                    ?value  "One"
                    ?callback list("oferRadioButtonCB()")
            ; extra entries for radio button options two and three
            ; these won't be mapped to start off with.
            optionTwo=hiCreateStringField(
                    ?name 'optionTwo
                    ?prompt "Option for Two"
            optionThree=hiCreateStringField(
                    ?name 'optionThree
                    ?prompt "Option for Three"
            ; the user data button
            sep3=hiCreateSeparatorField(?name 'sep3)
            userData=hiCreateButton(
                    ?name 'userData
                    ?buttonText "User Data"
                    ?callback "oferDisplayUserDataForm()"
            hiCreateAppForm(
                ?name 'oferExampleForm
                ?formTitle "Ofer's example form"
                ?callback 'oferExampleFormCB
                ?fields
                    list(
                        list(templateFile 0:0 600:30 200)
                        list(templateLoad 100:5 45:20)
                        list(templateSave 150:5 45:20)
                        list(sep1 0:35 600:0)
                        list(libName 0:40 600:30 200)
                        list(cellName 0:70 600:30 200)
                        list(viewName 0:100 600:30 200)
                        list(browse 200:130 100:25)
                        list(sep2 0:165 600:0)
                        ; a bug related to positioning of radio fields
                        ; was fixed in IC61, so need to specify the y coordinate
                        ; in IC5141 lower than expected position
                        if(dbGetDatabaseType()=="CDBA"
                            list(radio 0:190 600:0 200)
                            list(radio 0:170 600:0 200)
                        list(sep3 0:205 600:0)
                        list(userData 200:220 100:25)
            ; store the extra fields on the form, ready for later
            oferExampleForm->extraFields=
                list(nil 'optionTwo optionTwo
                        'optionThree optionThree)
            oferExampleForm
    *                   oferCreateUserDataForm()                   *
    *                  Creates the user data form                  *
    procedure(oferCreateUserDataForm()
        let((userFilename userRadio)
            userFilename=hiCreateStringField(
                    ?name 'userFilename
                    ?prompt "Filename"
            userRadio=hiCreateRadioField(
                    ?name 'userRadio
                    ?choices list("a" "b" "c" "d")
                    ?value "a"
                    ?prompt "Another Radio"
            ; example - don't bother filling
            hiCreateAppForm(
                ?name 'oferUserDataForm
                ?formTitle "Ofer's User Data"
                ?fields list(
                    userFilename
                    userRadio
    *                      oferSaveTemplate()                      *
    *              Callback code to save the template              *
    procedure(oferSaveTemplate()
        let( (fileName fport)
            fileName=oferExampleForm->templateFile->value
            when(fileName==""
                error("Must specify template filename")
            fport=outfile(fileName)
            unless(fport
                error("Could not write to template file %s" fileName)
            fprintf(fport "oferKeys='(nil\n")
            ; output all of the main form keys
            foreach(key '(libName cellName viewName radio)
                fprintf(fport "  %s %L\n" key get(oferExampleForm key)->value)
            ; output all of the user data form keys
            foreach(key '(userFilename userRadio)
                fprintf(fport "  %s %L\n" key get(oferUserDataForm key)->value)
            ; end of the file
            fprintf(fport ")\n")
            close(fport)
    *                      oferLoadTemplate()                      *
    *              Callback code to load the template              *
    procedure(oferLoadTemplate()
        let( (fileName)
            when(fileName==""
            ; load it, and trap any errors. The file is just skill
            ; code, so can be loaded.
            errset(load(fileName) t)
            ; the keys are all in a disembodied property list called oferKeys
            ; input all of the main form keys
            ; use get(), because oferKeys->key won't work, because the key variable
            ; needs to be evaluated.
                when(get(oferKeys key)
                    get(oferExampleForm key)->value=get(oferKeys key)
                    get(oferUserDataForm key)->value=get(oferKeys key)
    *                      oferSyncBrowser()                       *
    *                 Synchronise with the browser                 *
    procedure(oferSyncBrowser()
        ddsSyncWithForm(
            oferExampleForm
            'browse
            'libName
            'cellName
            'viewName
    *                      oferRadioButtonCB()                      *
    *   Callback for the radio button on the form - this adds or    *
    *       subtracts the dynamic fields. The dynamic fields        *
    * are created at startup, and stored in a disembodied property  *
    * list on the form, and the form positions are calculated based *
    *        on the current positions of fields on the form.        *
    procedure(oferRadioButtonCB()
        let((radioVal newOffset newPosition oldPosition
                (currentOffset 0) (fieldHeight 30) newYcoord)
            ; determine the offset of the bottom fields at the moment
            when(oferExampleForm->optionTwo
                currentOffset=currentOffset+fieldHeight
            when(oferExampleForm->optionThree
            ; determine the offset that we want, based on the radio
            ; button value
            radioVal=oferExampleForm->radio->value
            newOffset=case(radioVal
                ("Two" fieldHeight)
                ("Three" fieldHeight*2)
                (t 0)
            ; shift the two bottom fields by the appropriate amount
            foreach(field '(sep3 userData)
                ; calculate the new position from the old, offset accordingly
                oldPosition=car(hiGetFieldInfo(oferExampleForm field))
                newPosition=xCoord(oldPosition):yCoord(oldPosition)
                            +newOffset-currentOffset
                hiMoveField(
                    oferExampleForm
                    field
                    newPosition
            ; delete form fields if they're not needed
            when(radioVal=="One" && oferExampleForm->optionTwo
                hiDeleteField(oferExampleForm 'optionTwo))
            when(radioVal!="Three" && oferExampleForm->optionThree
                hiDeleteField(oferExampleForm 'optionThree))
            ; determine where the extra fields will be placed
            newYcoord=yCoord(car(hiGetFieldInfo(oferExampleForm 'radio)))+
                if(dbGetDatabaseType()=="CDBA" 10 30)
            ; add the two fields if they're needed and not there already
            when(radioVal=="Two" || radioVal=="Three"
                unless(oferExampleForm->optionTwo
                    hiAddField(oferExampleForm
                        list(oferExampleForm->extraFields->optionTwo
                            0:newYcoord 600:30 200))
            when(radioVal=="Three"
                unless(oferExampleForm->optionThree
                        list(oferExampleForm->extraFields->optionThree
                            0:newYcoord+fieldHeight 600:30 200))
    *                  oferDisplayUserDataForm()                   *
    *  Display the user data form - callback from the main form.   *
    procedure(oferDisplayUserDataForm()
        hiDisplayForm(oferUserDataForm)
    *                    oferExampleFormCB(form)                    *
    * The form callback - doesn't do much except print out what has *
    *                         been entered                          *
    procedure(oferExampleFormCB(form)
        printf("You entered cellView %s/%s/%s\n"
            form->libName->value
            form->cellName->value
            form->viewName->value
        printf("The radio button was set to %s\n"
            form->radio->value
        printf("And the user data fields were\nfilename: %s\nradio: %s\n"
            oferUserDataForm->userFilename->value
            oferUserDataForm->userRadio->value
    *                        oferExample()                         *
    *                       Main entry point                       *
    procedure(oferExample()
        unless(boundp('oferExampleForm)
            oferCreateForm()
        unless(boundp('oferUserDataForm)
        hiDisplayForm(oferExampleForm)
  • ToMWUT
     Thanks Adrew, your code was very helpful.
    ToM
  • frasheed
    frasheed over 12 years ago
     Hello, I am totallynew to the community and in SKILL too :) , Thanks for the deep explainition of dealing with a form , But I have a question that after taking user input I will manipulate the dataand use it in my next part of code. When I run my code the form appers for the user input at the same time the remaining code also get excuted. I want to pause the code till user enter the values and press the OK button in form , Can you please give me hint of that
     Farhan
    Farhan,
    What you should do is not execute code immediately after hiDisplayForm(), but instead specify a callback using ?callback with hiCreateAppForm. That way you can tell it a function to call when the form is OK'd or Apply'd (you can also supply a different function to call if the form is cancelled).
    Relying on the blocking behaviour of a form is not considered good practice (the forms are normally blocking unless you pass ?dontBlock t to hiCreateAppForm) - a callback is the right way to do this.
    Unfortunately my example above doesn't have a callback on the main form (it does now, because I've edited it), but you could add:
    ?callback 'oferFormExampleCB
    to the hiCreateAppForm() example. Not quite sure how that went missing, but must have been a while back because even in the original version in my version control system back in 1999 I neglected to pass ?callback. I'll fix the code above
  • frasheed
    Thanks for the detailed reply, that was really helpful. I have one more question that If I want to take numeric input values from user then  can you please give me hint for any function ?  Thanks
    Farhan
    EDIT: I just read a function "hiCreateFloatField" , is there any function for integer data input
    What you mean, like hiCreateIntField()?
    This is easily found in both cdsFinder, and also in cdnshelp.. Suggest you look in the documentation at all the field creation functions...
  • frasheed
    Hi ANdrew,
     Thanks for the quick reply, I got it :)
    Farhan
