  3. How to convert integer to string?
  • Replies 18
  • Subscribers 154
  • Views 47842
latha
latha over 16 years ago
Can anybody let me know skill the function how to convert integer to string?
Ex: a=123 (integer)
I need
a="123" (string)
    Andrew Beckett over 16 years ago +1
    sprintf(a "%d" a)
    sprintf(a "%d" a)
  • babji
    babji over 16 years ago
     pcExprToString should work as well.
  • skillUser
    skillUser over 16 years ago
    I think that Andrew's answer is the way to go, use sprintf().  You can perform further processing using the cdfFormatFloatString() function too:
      a = 123
      => 123
      formatted_a = cdfFormatFloatString( sprintf(nil "%d" a) "K")
      => "0.123K"
    Lawrence.
  • gheryiesan
    gheryiesan over 16 years ago
     oh..its really works well..
  • pvvikas
    pvvikas over 16 years ago
    Thank you so much Lawrence. This is exactly what I wanted. I needed to label output of a decoder as "row0", "row1" ..etc. Thanks Vikas
  • Peach99
    Peach99 over 16 years ago
    Another question: How can I convert string to integer like this: "pmos"  to  pmos ???
    Regards
    Daniel Pietsch
    Daniel,
    Sorry, that doesn't make sense. "pmos" is a string, but pmos is not an integer. What are you actually trying to do? I could tell you how to convert a string to a symbol, but I'm not sure that's what  you actually want?
  • Peach99
    I know that my statemant was wrong and I have found the correct function (stringToSymbol) I think! Thank you all the same!
    Regards
    Daniel Pietsch
  • DonWP9
    DonWP9 over 13 years ago
    How do you convert a string to a symbol or w_windowId?  I am using Ocean and want to make the w_windowId variable in the hardCopy command from strings I created. This way I can change the windowId with my program based on other variables.  I do not see the stringToSymbol function as described by another user.
     var = "window1"
    convertering steps to make "window1" to window1 (symbol or windowId)
    HardCopy(window1)
    Thanks for your help.
    Don
  • skillUser
    skillUser over 13 years ago
    Hi Don,
    The stringToSymbol function is a core SKILL function, so it is available in OCEAN.  You could also choose to use concat() for converting a string to a symbol - concat does not complain if you pass it either a string or a symbol, so it may be a little more flexible than stringToSymbol, depending on your usage of the function.
    In your post you mention "window1" - I'm used to seeing window id's like window:5 but perhaps yours is different because it is a waveform window?  However, if you have a window id like window:5 you can use the window function to return such an id, e.g.
    window(5)
    => window:5
    I hope this helps!
    Best regards,
    Lawrence.
