  3. Open "Choosing Analyses form" for specific analysis with...
  • Views 2514
Open "Choosing Analyses form" for specific analysis with skill
fatcat1206
fatcat1206 over 10 years ago
Hi All
I am tring to open "Choosing Analyses form" for specific analysis with skill.
What I found is "sevEditSelectedAnas(session)", it can open the "Choosing Analyses Form"
but it requires to select the analyses first, and I cannot find an API to select the analysis.
What I need is something similar as "sevEditSelectedAnas(session)"
instead of having one argument, it can receive the second argument as "analysis name".
Thus some functions like "xxxSevEditAnas(session anaName)"
Then I can open "Choosing Analyses form" for specific analysis defined by the second argument.
Best Regards
Yi
  • fatcat1206
    Hi All
    I just find a work around for my question.
    on the beginning, I just bring out the "Choose Analyses Form" with "sevEditSelectedAnas()" API.
    Then with "SISdisplayedFormList()", I create a list for all the displayed form.
    by some filtering, I can find the "Choose Analyses Form" of specified test session.
    Then I change the value of "asiiAnalysisRadioField" to the analyses I want.
    It was not a perfect solution, but it works for me :)
    Please find the procedure below.
    Best Regards
    Yi
    procedure(SISsevEditAnas(session anaName)
    let((
        analysisForm
        analysisForm = eval(car(setof(x SISdisplayedFormList() and(eval(x)~>sevSession == session eval(x)~>asiiAnalysisRadioField))))
        analysisForm ->asiiAnalysisRadioField->value = anaName
    );let
    );proc
    procedure(SISdisplayedFormList()
    let((
        displayedFormList
        displayedFormList = nil
        foreach(form hiFormList()
            when(and(hiIsForm(eval(form)) hiIsFormDisplayed(eval(form)))
                displayedFormList = cons(form displayedFormList)
            );when
        );foreach
        displayedFormList
    );let
    );proc
  • fatcat1206
    Hi All
    Some update after I notice the form bring out by "sevEditSelectedAnas(session)" would stop the executing of the script.
    the filtering is not applied to only the displayed form, but to all the forms.
    "sevEditSelectedAnas(session)" is called in the end.
    let((
        analysisForm = eval(car(setof(x hiFormList() and(eval(x)~>sevSession == session eval(x)~>asiiAnalysisRadioField))))
        when(and(analysisForm hiIsForm(analysisForm))
        );when
        analysisForm
    );let
    );proc
    let((
        analysisForm
    );let
    );proc
    - See more at: community.cadence.com/.../36047
    let((
        analysisForm
    );let
    );proc
    sevChooseAnalysisForm(session 'tran)
    Pass the sev session as the first argument, and analysis name as a symbol for the second.
  • fatcat1206
    Hi Andrew
    Thank you very much.
    it works.
    There might be an type error for the API.
    sevChooseAnalysesForm(session 'tran)
    Best Regards
    Yi
    Sorry Yi, my mistake. Silly typo on my part.
