  3. Suppressing HDL Parser Warning and port mismatch warnin...
  • Views 19352
Suppressing HDL Parser Warning and port mismatch warnings
Aarbuz
Aarbuz over 9 years ago
I have a script that calls the SKILL functions vmsUpdateCellViews for every cell of a list of libraries.
I want this to be automated, but calling this function for each cell produces a pop up warning which says the following:
"HDL Parser Error/Warnings: Parsing of Verilog file produced warnings. Do you want to view the warnings file?"
The warning relates to a lack of permission to access a cds.lib file which is not important to the functionality of the script.
For certain cells there is a warning relating to a port mismatch between the cellview (functional) and a symbol view, which is due to the lack of VDD and VSS pins.
I would like to suppress these if at all possible.
There is a function called envSetVal which can suppress warnings of certain types, but I can't find a list of the tools and environment variables anywhere. Could someone point me in the right direction?
The version of Cadence Virtuoso is IC6.1.7-64b.500.6. Thanks in advance.
Andrey
    Andrew Beckett over 9 years ago +1
    Andrey, The first can be suppressed by doing: setenv NCVLOGOPTS "-NOWARN DLCPTH" or export NCVLOGOPTS="-NOWARN DLCPTH" (depending on your shell) before starting virtuoso. Most ncvlog warnings…
  • skillUser
    skillUser over 9 years ago
    Hi Andrey,
    You can find the list of variables and their default settings (per tool) by looking in your installation hierarchy, for example for the schematic tool the 'central' .cdsenv is here: `cds_root virtuoso`/tools/dfII/etc/tools/schematic/.cdsenv
    Maybe you can find an appropriate variable that might help suppress the unwanted warnings?
    Best regards,
    Lawrence.
    Andrey,
    or
    (depending on your shell) before starting virtuoso. Most ncvlog warnings can be suppressed by putting a definition in the hdl.var, but this doesn't work for DLCPTH (if that was the warning  you were getting)
    For the other, I think it's:
    envSetVal("schematic" "disablePortOrderPopup" 'boolean t)
    envSetVal("schematic" "vicCheckPinOrder" 'boolean nil)
    vmsCrossViewCheck=nil
  • Aarbuz
    Your suggestions worked perfectly. Thank you!
    Lawrence, thanks for pointing me in the right direction. I'll make a note of this should I need to do something similar again.
    Andrey
