  2. AWR Design Environment
  3. How to get interpolated data between the actual data points...
  • Subscribers 22
  • Views 8175
How to get interpolated data between the actual data points under an MDIF data file format
SimTech
SimTech over 4 years ago
The variable value of an MDIF data file comes back as an index instead of the interpolated value. Is there a way I can interpolate data between indexes?
Enter Vd=2 or a higher number. The result comes back as an index instead of the attenuation value. If the variable set to 2 gives a 1dB result, 1dB is #2 in the index. Also, if Vd=7 or a higher number is entered, no value is returned, and no interpolation happens.
To achieve this, enable interpolation and enter any numeric value or assign to a variable and the results are interpolated between the actual data points.
1.  Change the interpolation settings globally by choosing Options > Project Options to display the Project Options dialog box. Select the Interpolation/Passivity tab and check the checkbox against Enable parameter interpolation.
2.  Enter Vd=7 or a higher number.
3.  You can achieve the same setting by doing the following steps:
       a)  Right-click the local data file and choose Options to display the Project Options dialog box.
       b)  Select the Interpolation/Passivity tab and ensure that the Use project defaults checkbox is cleared to allow you to select Enable parameter interpolation.
Team SimTech
Cadence Design Systems
