  2. AWR Design Environment
  3. How to make scaled prints of a layout in AWR tool
  • Subscribers 34
  • Views 10441
SimTech
SimTech over 4 years ago
In the AWR Design Environment platform, you can control the scaling of a layout print or set ratio 1:1 of the layout print. Usually, this is used in exporting the design to other tools.
While the layout window is active, select File > Page Setup. In the 2D Layout Print Options section, select Scale to and specify the print scaling.
The same is applied for schematics, system diagrams, and graphs as well.
Team SimTech
Cadence Design Systems
  • turkeylever
    turkeylever over 2 years ago
    You can change the layout print scale on the AWR Design Environment platform. When exporting designs to other tools, this feature is frequently used. Simply open the layout window, go to File > Page Setup, and under the 2D Layout Print Options section, select "Scale to" to specify the appropriate print scale.
