  2. AWR Design Environment
  3. Uses of Graph Data Sets
  • Subscribers 22
  • Views 8455
SimTech
SimTech over 3 years ago
You can use graph data sets to save and restore the current state of all your graphs, even after opening a project.
Right-click on the Data Sets node in the project and select Options to see several options that control graph data sets, as highlighted in the following image.
The current setup will save a graph data set and restore it when the project is reopened. This way, you can see the data that was on your graphs when you last closed the project.
Additionally, you can right-click on the Data Sets note in the project tree and choose the option to save the current graph traces to a data set, as shown below.
Finally, at any time, right-click on a graph data set (Under the GRAPHS node of Data Sets) and select the following option to update graphs to data from the data set.
Team SimTech
Cadence Design Systems
