  2. AWR Design Environment
  3. How to save an S2P output file from a cascade circuit with...
  • Subscribers 23
  • Views 8854
How to save an S2P output file from a cascade circuit with different port impedance
SimTech
SimTech over 3 years ago
For a cascaded circuit with different port impedance or not 50 ohms ports, the output file generated using NPORTF does not match with the original S-parameter or graph.
To resolve this mismatch and generate an output file that matches the original data, do the following steps:
1-  Right-click Graphs and select New Graph. Select Tabular and then click Create and Add New Measurement.
2-  From the menu bar, click Graph > Export Trace Data. Save the data in .txt format.
3-  Next, edit the header part of the saved .txt data as per AWR Text Data File format.
Now, plot the imported .txt data with the original data; the result will be the same.
Team SimTech
Cadence Design Systems
