  2. AWR Design Environment
  3. How to relate AWR v16 optimizers to new AWR v22.1 optim...
  • Subscribers 22
  • Views 7044
How to relate AWR v16 optimizers to new AWR v22.1 optimizers
SimTech
SimTech over 3 years ago
In the AWR Design Environment platform V22.1 software, the optimizer list is reorganized and reduced to simplify selection. Following optimizer table maps V16 software optimizers by names to their equivalent in V22.1 software:
V16 Optimizer
V22.1 Optimizer Equivalent
Advanced Genetic Algorithm
Adv Genetic Algorithm
Conjugate Gradient
Gradient Optimization
Differential Evolution
Diff Evolution
Direction Set Method
Discrete Local Search
Grid Search
Genetic (Gaussian Mutation)
Genetic (Uniform Mutation)
Kapu Optimizer
Kapu
Lineup Optimizer
Lineup Optimizer
Parallel Advanced Genetic Algorithm
Parallel Kapu
Kapu
Parallel Particle Swarm
Particle Swarm
Parallel Random Local
Random
Parallel Robust Simplex
Robust Simplex
Particle Swarm
Particle Swarm
Pointer – Gradient Optimization
Pointer – Hybrid#
Pointer – Robust Optimization
Pointer – Hybrid
Random (Global)
Random
Random (Local)
Random
Robust Simplex
Robust Simplex
Simplex Optimizer
Robust Simplex
Simplex Optimizer (Local)
Robust Simplex
Simulated Annealing (Simplex)
Robust Simplex
# A new Pointer: Hybrid optimizer method is introduced, which combines the best performance of several optimizers to produce a top-performing algorithm on a very wide range of problems.
Note that all optimizers except Lineup and Gradient:
  • Can run in parallel
  • Can use discrete variables and step sizes
  • Now require variable constraints
The new optimizers are tested and found to perform as good as or better than the older optimizers they are mapped to, with no loss of capability on a wide range of problems. Note, however, that there may be exceptions. If an optimizer that is no longer available is required to achieve the best performance on a particular problem, contact Cadence Technical Support for assistance.
Unconstrained variables defined in the older projects must be updated with constraints to work with the new optimizers. Following are the steps to quickly add constraints:
  1. Open Variable Browser (choose View > Variable Browser).
  2. Type "1" in the Optimize column header to filter on optimized variables.
  3. Shift+select all displayed variables.
  4. Select the Constrained checkbox for the last selected variable to update the checkbox for all selected variables.
  5. Enter lower and upper bounds for the variables as a percentage or absolute delta of the current value by following the lower and upper bound value with a "%" or "#" sign, respectively. For example, to enter a lower bound that is 10 percent lower than the current value for all the variables, type "10%" in the Lower column for the last selected variable.
Now that you have read the article, answer the following questions in the comment box:
Q1. What is the primary objective of optimization techniques?
a) To find the best solution
b) To find any solution
c) To find a quick solution
d) To find the most complex solution
Q2. Which new optimization method in AWR v22.1 combines the strengths of multiple optimizers to produce high performance across a wide range of problems?
a) Pointer – Hybrid
b) Robust Simplex
c) Lineup Optimizer
d) Gradient Optimization
Team SimTech
Cadence Design Systems
