  2. AWR Design Environment
  3. How to plot graph from the data file in AWR 22.1
  • Subscribers 22
  • Views 7323
SimTech
SimTech over 3 years ago
When there is a data file in .txt format (for example, V1_V2.txt) with data that needs to be imported to AWR 22.1, and the graph needs to be plotted, perform the following steps:
Step 1: Right-click on Data Files, select Import Data Files, and browse the V1_V2.txt file.
Step 2: Right-click on Graph > New Graph > Rectangular. Right-click on the graph select Add measurements. Choose the following settings for Measurement Type and Measurement. Choose Data File Name as V1_V2 from the dropdown menu and respective columns for X-axis and Y-axis. Click OK.
Step 3: Double-click on the graph to see it.
Team SimTech
Cadence Design Systems
