  2. AWR Design Environment
  3. Shortcut to add elements to the schematic/system diagram...
  • Subscribers 22
  • Views 2726
Shortcut to add elements to the schematic/system diagram in AWR
SimTech
SimTech over 2 years ago
When you need to add an element to a schematic or a system block to a system diagram, you usually pick and drop elements from the Elements tab as shown below.
Instead, you can use Ctrl+L shortcut to add elements quickly. When you press Ctrl+L, the following dialog box appears. Here, you can search by typing the name of the required element to display Circuit Element for schematics or System Block for system diagrams. You can then add the element to the circuit schematic/system diagram.
Team SimTech
Cadence Design Systems
