  2. AWR Design Environment
  3. Parallel Optimization in AWR MWO - Unable to connect to...
  • Subscribers 22
  • Views 4069
Parallel Optimization in AWR MWO - Unable to connect to data source
StefanE
StefanE over 2 years ago
when trying to performe an optimization using parallel jobs (Num of Parallel Jobs > 4) the solver is unable to connect to data source. An Optimization with only one jobs is running without any problems.
Do you have any ideas? Thank you in advance.
Best regards,
Stefan
  • OscPn
    OscPn over 2 years ago
    Hi Stefan,
    Are you trying to simulate on local or remote computer? May be if you are simulating on remote computer then please check if required licenses are checked or not.
    Santosh
  • StefanE
    Hi Santosh,
    the optimization is running on my local computer.
    Best Regards,
    Stefan
  • OscPn
    OscPn over 2 years ago in reply to StefanE
    Hi Stefan,
    The second error "Unable to connect to data source named" It seems the project is running with missing data file. The first error
    Regarding optimization using parallel jobs issue Check the box to set the Options > Default Circuit Options > Job Scheduler > Simulate as AWRDE Server Job option. Also, set the Options > Default EM Options > Job Scheduler . Max Parallel Jobs Per Node to be as high as (or higher than) the number you are trying to use in the optimizer.
    Also if you are using older version (V17.01, 17.02, etc.), try the project with the later version i.e. AWR v17.4. If still any issue comes up please email the project.
    Santosh
  • StefanE
    StefanE over 2 years ago in reply to OscPn
    Hi Santosh,
    thank you very much.
    I still get the same error. I´m using version 22.1 (17.03r).
    Stefan
  • OscPn
    Hi Stefan,
    Thank you very much.
    Please contact customer support.
    Santosh
