  2. AWR Design Environment
  3. Wide gap for a package isn't liked by MGAP2
  • State Verified Answer
  • Subscribers 21
  • Views 2488
AB202408227656
AB202408227656 over 2 years ago
I need to leave a space in my layout for a 2.2mm wide package so I've tended to use a MGAP2 in between the in & out microstrip. This works fine for EM simulation but for linear analysis it gives a tiresome error
S/H=2.75 must be <1
Is there any way to make it degenerate in the obvious fashion to being no connections in this case?  When I remove them to linear simulate my layout gets all messed up!
Alan
  • OscPn
    OscPn over 2 years ago in reply to AB202408227656 +1 verified
    Yes, MGAPX will work.
  • OscPn
    0 OscPn over 2 years ago
    This model is valid within the following ranges (where H is the substrate thickness):
    0.5 < W/H < 2.5
    0.1 < S/H < 1
    1 < εr < 216
  • AB202408227656
    0 AB202408227656 over 2 years ago in reply to OscPn
    Thank you - so I need to use another model.  MGAPX works and now I have my first real EM co-simulation results.
    Alan
  • OscPn
    +1 OscPn over 2 years ago in reply to AB202408227656
