  2. AWR Design Environment
  3. Ground flood in Layout
  • Subscribers 23
  • Views 3311
MTalha
MTalha over 2 years ago
I have a complex layout with S-parameter files whose artwork are added to each file. I want to assign a net to each pad in layout so that when using voiding constraints pads with GND net name are connected to ground flood.
I can only assign the whole artwork a single net name which shorten all pads to ground. Is there another way to make this connection right?
  • MTalha
    0 MTalha over 2 years ago
    I tried to make a net name to each pad in the cell library but it's not saved. (I write a net name then press Ok and when i recheck the net name, I don't find it)
  • OscPn
    0 OscPn over 2 years ago in reply to MTalha
    Not sure if I understand the question correctly,  If you want to assign Net name for each Pad try to create layout directly instead of using Artwork.  Further, I suggest for this you can contact customer support (submit a support case after logging in) with the project - that way an Application Engineer in team can look at this together with you.
