  2. AWR Design Environment
  3. Importing excel file into AWR
  • State Verified Answer
  • Subscribers 22
  • Views 4084
MTalha
MTalha over 2 years ago
I have some data in Excel file that I want to import in AWR to plot it.
I save the file as .csv file and after importing it into AWR, the following error apears
" 0 Column heading expected, must be in name(type,units) format: Line 1 in file: new"
  • OscPn
    OscPn over 2 years ago +1 verified
    I guess this is coming due to column heading format. The column headings section, if present, provides additional information about the data columns of the file. If this section is present, you must specify…
  • MTalha
    MTalha over 2 years ago in reply to OscPn +1 verified
    Thanks, this gives me the cause of the error. The format must be checked inside AWR and the heading must be exactly like this Excel usually adds (" ") for each word which AWR doesn't understand or…
  • OscPn
    +1 OscPn over 2 years ago
    I guess this is coming due to column heading format. The column headings section, if present, provides additional information about the data columns of the file. If this section is present, you must specify a column heading for each data column. A column heading has the following format:
    [name]([type][,units])
    where [name] is the name of the column, [type] is the type of data and [units] is the units for the data. Each of the parts is optional, although the "(,)" and "," punctuation are required.
    To know more check the help page:
    AWR Design Environment User Guide > Data Files > Data File Formats
  • MTalha
    +1 MTalha over 2 years ago in reply to OscPn
    Excel usually adds (" ") for each word which AWR doesn't understand or adds unnecessary , between each value.
