  2. AWR Design Environment
  3. Matching Differential impedance (Balanced) to a 50 Ω single...
  • Subscribers 23
  • Views 2110
Matching Differential impedance (Balanced) to a 50 Ω single ended
MTalha
MTalha over 1 year ago
nRF24L01+ transceiver IC has a balanced output for antenna and it's recommended to load it with 15+j88 Ω to get maximum power. I tried to re-simulate the circuit but it didn't work. I doubt the setup for simulation is not correct. How Differential to single ended matching is made anyway, I didn't encounter. I attached pics of Data sheet and the simulation setups. (I couldn't upload images inside the post due to a system error)
https://easyupload.io/lpvd6l
  • Tangolima
    Tangolima over 1 year ago
    You need balun (balanced to unbalanced) transformer to transform single-ended to balanced.
    -TL
