  2. AWR Design Environment
  3. How to replicate AntPat_EF option in the Output File menu...
  • State Verified Answer
  • Subscribers 21
  • Views 3133
How to replicate AntPat_EF option in the Output File menu with an EM structure and selecting an excitation subcircuit for the EM structure
Pablo Soto
Pablo Soto over 1 year ago
In the past months I've been working with AWR in order to simulate the electromagnetic behaviour of my antenna design using Analyst simulator.
As part of the project, I have two separated parts: the EM structure of the antenna (Fig.1) and a non-linear decorrelating net in order to separate signals from different frequency bands (Fig.2).
  • Fig. 1: The EM structure
  • Fig. 2: Both the EM structure andthe non-linear circuit. This is the simulation's objective.
I've been able to extract, simulate and visualize the 3D Antenna pattern for both EM structure alone (with ANTENNA_3D annotations) and the EM structure with the excitation from a subcircuit  as in Fig. 2 (with ANTENNA_CKT_3D annotations).
However, I need to export the radiation patterns to a file in order to apply data analisys.
I can export the data I need from an EM structure using the AntPat_EF option in the Output File menu because it sweeps both Thetha and Phi values for a given frequency.
This option is exactly what I need, but I can't find the same option with circuit excitation.
Is there a way to replicate AntPat_EF option in the Output File menu with an EM structure and selecting an excitation subcircuit?
Thank you in advance,
Salud!
  • CurtisAWR
    CurtisAWR over 1 year ago +1
    Hi Pablo, It looks like at the current time, there is not an option to write an output file for an in-Situ version of this measurement (specifying the EM Structure + an Excitation Schematic). I'm told…
  • CurtisAWR
    CurtisAWR over 1 year ago in reply to Pablo Soto +1 verified
    Hi Pablo, At this time, I don't see a way to do it in a straightforward manner. If you are able to submit this as a support case and attach your project, one of our support AEs may be able to try to…
  • CurtisAWR
    0 CurtisAWR over 1 year ago
    Hi Pablo,
    I'm told that this is an existing enhancement request to development.  I don't have any specifics about its priority or schedule.
    Curtis
  • Pablo Soto
    0 Pablo Soto over 1 year ago in reply to CurtisAWR
    Thank you so much fo your reply.
  • Pablo Soto
    Hello again Curtis.
    I tried many things but I can't really find the right combination in order to replace (or recreate) this feat.
    Could you please suggest any idea to write an output file for the EM Structure + an Excitation Schematic?
    Maybe combine 2 files exporting some measurements or maybe exciting the EM port with the exact power measured on the Schematic.
    Pablo
  • CurtisAWR
    +1 CurtisAWR over 1 year ago in reply to Pablo Soto
    Hi Pablo,
    If you are able to submit this as a support case and attach your project, one of our support AEs may be able to try to experiment with it.  That would probably be our best chance to determine whether a workaround is possible for this issue.
    Curtis
