  2. AWR Design Environment
  3. How to get radiation patterns of Antenna array for a Time...
  • Subscribers 22
  • Views 2243
How to get radiation patterns of Antenna array for a Time modulated Signal.
SN202411058445
SN202411058445 over 1 year ago
Hi ,
I am working on simulating of Time modulated antenna arrays. I am able to get the time modulated input Rf signal but while feeding into the antenna array I am not able to get the total power radiated vs theta plot.
I am getting a error ""  array.AP_HB.$FSAMP:DB(|PPC_TPwr_CKT(RF_Switch_Array.AP_HB,SUBCKT.S6,1,1,0,2,1)|)[9] : Excitation circuit must use singe tone excitation "".
i am using a pulse signal in switch block for blocking and allowing of power to the antenna array.
Please explain what is mean by the error and how to get the simulation ?
  • OscPn
    OscPn over 1 year ago
    Please file a Case with ASK.   An AE will be assigned to work with you on this.
    Santosh
  • SandyRF
    SandyRF over 1 year ago
    If you have ASK access- This RAK will help.
    Article (20508282) Title: Designing a Phased Array Antenna in Cadence AWR® Design Environment
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009li2XEAQ
    For any queries, I also recommend searching the ASK platform (support.cadence.com/.../HomePage). If you can't find what you're looking for, please raise a support ticket with Cadence for further assistance.
