  2. AWR Design Environment
  3. Nport_FV
  • Subscribers 22
  • Views 1733
Nport_FV
NF202501292154
NF202501292154 over 1 year ago
using a NPORT_FV element I should be able provide a CSV file including a list of Sparameter files and then to select the respective Sparameter by an index.
Can someone provide me an example or at least an example of a CSV file?
Thanks and br
  • OscPn
    0 OscPn over 1 year ago
    NPORT_FV is a variation of the NPORT_F model. All common parameters behave the same in both models. NPORT_FV includes a FILES parameter that allows you to specify a comma-separated list of S-parameter file names. This list should include file names only-- not any directory path specifiers. Using the INDEX parameter, you select the particular S-parameter that is used for the model. NPORT_FV allows a simple way to sweep, tune, or optimize over a set of S-parameter files by changing the INDEX parameter.   To know more check the help page:
    Tunable N-Port S-Parameter Block (uses a list of file names): NPORT_FV
