  2. AWR Design Environment
  3. AWR VSS Detecting a Interfering Signal
  • Subscribers 23
  • Views 1943
CB202501275646
CB202501275646 over 1 year ago
In my design I have implemented a jamming signal (tone block), transmitted via antenna,  to interferer with a specific frequency in the 5GHz band, for example 5.18GHz so channel 36; this signal is received via an antenna. How would I go about designing a detector that could sense this interference at the receiving antenna and perhaps swich to a different channel or the 6GHz band.
  • cdsba
    0 cdsba over 1 year ago
    Here is one way to create a power threshold detector in VSS
    The PWR_MTR reads the power at the output of the receive antenna. The DECIDE block outputs '0' when the power level is below a threshold set by the SRC_R block. The DECIDE block outputs '1' when the power exceeds the threshold value. The output of the DECIDE block then controls the switch to change RF channels.
