  2. AWR Design Environment
  3. Power
  • Subscribers 21
  • Views 3845
Power
CB202501275646
CB202501275646 over 1 year ago
What blocks and in what layout would I need to convert Power in dBm to the linear scale.
  • OscPn
    0 OscPn over 1 year ago
    Question is not clear,  do you want to convert dBm to milliwatt? through block or equation?
  • CB202501275646
    0 CB202501275646 over 1 year ago in reply to OscPn
    Hi, to milliwatt through either a block or an equation
  • OscPn
    0 OscPn over 1 year ago in reply to CB202501275646
    Ok, can you share why you want to convert between dBm and mw.  are you trying to change the units on a graph?  Change units in a project?  Set the power level on a source?
