  2. AWR Design Environment
  3. Unrecoverable numerical error while calculating a Green...
  • Subscribers 22
  • Views 3349
Unrecoverable numerical error while calculating a Green's function. Please send an example of this problem to AWR support.
Romolo Marcelli
Romolo Marcelli over 1 year ago
Hello to everybody. I got the error about calculating the Green's function when simulating the attached configuration. The aim is to simulate a capacitor for dielectric constant retrieval. I used both AFS and no-AFS simulation, changed already the cell size (form 1 to 10 micron) anCapacitor SiO2.emld the kind of port, even if I would prefer to have an internal port. Two dielectrics are simulated but the error is the same.
  • Romolo Marcelli
    Romolo Marcelli over 1 year ago in reply to OscPn +1
    Thank you. I will download the latest release, probably, as you say, it is due to this. I will be back to you for confirmation.
  • Romolo Marcelli
    0 Romolo Marcelli over 1 year ago
    BTW, the meshing is performed without problems
  • OscPn
    0 OscPn over 1 year ago in reply to Romolo Marcelli
    Hi Romolo,
    This error is not present in the latest version of the AWR tool. You may want to try that.
  • Romolo Marcelli
    0 Romolo Marcelli over 1 year ago in reply to OscPn
