  2. AWR Design Environment
  3. New Application Note: Differential Filter Design Using AWR...
  • Subscribers 22
  • Views 5131
New Application Note: Differential Filter Design Using AWR Design Environment
NV202504147220
NV202504147220 over 1 year ago
The AWR Design Environment provides strong capabilities for designing and evaluating differential filters. The application note explains the process of designing differential filters and provides insight into the benefits of the MMCONV component when measuring common and differential modes.
Topics in the application note include:
  • iFilter Design: Low-pass filter, High-pass filter, Band-pass filter, and Band-stop filter
  • Convert single-ended filters into differential filters
  • Measurement techniques including common-mode and differential mode, common mode rejection ratio (CMRR), and Mixed-mode converter (MMCONV)
  • Layout/design considerations and EM simulation
  • Optimization and yield analysis
This application note can be found using this link: support.cadence.com/.../ArticleAttachmentPortal
  • OscPn
    OscPn over 1 year ago in reply to Frank Wiedmann +2
    Yes. MMCONV is identical to that ideal balun. If you map the equations from page 3 of diff.pdf to those in the MWO_Element catalog for MMCONV, they are identical.
  • Frank Wiedmann
    0 Frank Wiedmann over 1 year ago
    Is MMCONV identical to the ideal_balun described in https://designers-guide.org/analysis/diff.pdf ?
  • OscPn
    0 OscPn over 1 year ago in reply to Frank Wiedmann
    MMCONV is a closed form model, this model is commonly used for differential circuit analysis but can also be used as an ideal power combiner/splitter (with an impedance transform) or magic-tee (with an impedance transform).
  • Frank Wiedmann
    0 Frank Wiedmann over 1 year ago in reply to OscPn
    This does not really answer my question (and is just a quote from https://support.cadence.com/apex/techpubDocViewerPage?path=awrMWOElements/awrMWOElements24.1_ISR2/Mixed-Mode_Converter__Closed_Form___MMCONV.html ).
  • OscPn
    • Vote Up +2 Vote Down
